Back up lens
Author Topic: Back up lens  (Read 2200 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Back up lens
« on: November 28, 2005 - 03:15:51 PM »
I have taken off my back up lens which came off in pieces and have found a replacement for it but would like to pull the D O D G E off to have it re-chromed is there a trick? I tried it on the broken lens and broke one of the studs on the D.  :frown:
« Last Edit: November 28, 2005 - 03:17:50 PM by Tropicalcats »
SOLD
Re: Back up lens
« Reply #1 on: November 28, 2005 - 03:19:21 PM »
I kinda think they are permanently mounted. At least I have never heard of anyone taking them off. For the record, that picture you posted doesn't look bad. Going for a show winner???
Re: Back up lens
« Reply #2 on: November 28, 2005 - 03:39:05 PM »
 No just a little anal.  I have been able to make the new ones shine and they will look fine. I was hoping to find a way to save the others as the lens is really bad. :bloated:
SOLD
Offline FY1 RT SE
Re: Back up lens
« Reply #3 on: November 29, 2005 - 10:11:12 AM »
You can get them off using a Dremel.
Re: Back up lens
« Reply #4 on: November 29, 2005 - 10:35:08 AM »
very nice. What bit did you use?
SOLD
Offline FY1 RT SE
Re: Back up lens
« Reply #5 on: November 29, 2005 - 11:24:22 AM »
3/16 ball bit, you need to grind the flares off the pins and then use a pin punch to remove the letter.  The lens needs to be supported very well or you could crack the plastic.
Re: Back up lens
« Reply #6 on: November 29, 2005 - 01:16:28 PM »
Thanks
SOLD
Re: Back up lens
« Reply #7 on: November 29, 2005 - 01:55:30 PM »
To follow up with a stupid question... would you just glue them back on?  :dunno:
Re: Back up lens
« Reply #8 on: November 29, 2005 - 02:07:01 PM »
Thats what I would plan. A clear type of epoxy.
Is that what you did FY1?
SOLD
Re: Back up lens
« Reply #9 on: November 29, 2005 - 02:26:37 PM »
I'm just thinking that would be tough since the letters are so thin. You don't want unsightly glue showing around the letters. Maybe it's possible though.  :screwy:
Offline FY1 RT SE
Re: Back up lens
« Reply #10 on: November 29, 2005 - 06:19:36 PM »
Epoxy works fine, don't see it when installed.
