Author Topic: 1971 prostreet duster VERY FAST!!  (Read 2479 times)
Offline mytmopar
  • 69 gtx 440 vert-71 chally 340 blown-70 R/T coronet
« on: December 08, 2002 - 08:57:35 PM »
 8) :o SUMITTED FOR YOUR APPROVAL 8) :o ;
heres what i got. on the dyno the trq was 459.5 lbs ft at 4900 rpm and hp is 488.6 at 5800 rpm. there is about 150 to 200 miles on motor so its broke in some. still a little tight if you ask me.heres the motor stuff (pro-built) used the best of everything
email for photos or question!
           bore  4.060
        stroke  3.578
             c.i.   371
  trw flat top forged pistons
  comp ratio 11 to 1                                     #40416 lunati
  steel I beam connecting rods                      int lift    582          32* btc  56* abc
  arp bolts                                                   exh lift  603           69* bbc 29* atc
  floated pins                                                int dur  308
  recondition to size                                     exh dur 318
                    rods .020    mains .025             lobe sep  int   106*
  steel crank                                                               exh  102*
                  rods .010    mains .010               #70973 solid mech lifters
  clevitte 77 rods and mains                           #73949 springs
  speed pro moly rings                                   #75702 steel retainers
  block decked  4 corner                                #77002 locks
  bronze freeze plugs                                     pete jackson gear drive (straight cut)
  clevitte cam bearing                                     crane gold roller shaft rockers alum.
  clevitte hi-vol oil pump                                   chrome moly pushrods
        balanced assy within 1 gram
heads
  4 barrel style  casting #3418915                       fuel system
  bronze guide                                               holley fuel pump
  bowl hog behind valve                                   barry grant 2 x 4 regulator
  ferra values  stainless                                   2 x 4 04777 holley 650 dbl pumpers
  valve adj.  int .018  exh .020                          fram fuel filter
  int  2.080  45% angle   30% back cut             aeo linkage kit
  ext 1.60   45% angle                                    #1995 weiand tunnel ram intake
  surfaced .040 flat cut                                    felpro hp gasket set
        blue head gasket .037 thick
        holley hp annailater ign w/ lazershot coil
       tranmission                                             electronic distributer
  727 torqueflite w/ reverse shift kit
  deep trans pan                                                   rearend
  tci 3500rpm stall converter                            ford 9" shortened
  qtr stick reverse cable shifter                         456 gears posi unit
  steel driveshaft w/ loop                                 moser axles
  professionally back halfed with 4 link and coil overs and steel tubbed
      misc
  wilwood 4 wheel disc                                   standard steering
  standard brakes                                          grant 3 spoke wheel
  autometer 5" tach w/ shiftlite                        ralley dash w/ 150 speedo
  15" centerline rims
  mickey thompson tires      front 26 x 8.5 x 15   rear 31 x 16.5 x 15
  racing bucket seats w/ covers
  6 pt roll cage padded
  go wing on back
  harwood pro-stock scoop on front
  fy1 lemon twist paint 3 coats base 3 coats clear
  71 stripe kit
  sharktooth grille
  set of centerlines w/ drag radials for strip
  placed 3 out of 4 shows (3 trophy's inc)
     needs:
  headliner
  bumpers could be chromed
email mckk423@aol.com or call 865 932-9421
price $19,500 OBO  8) 8) 8)
[attachment deleted by admin]
get in, sit down, buckle up, and hold on! see you later, BYE!!
