Headers vs manifolds
Author Topic: Headers vs manifolds  (Read 3446 times)
Offline basement
« on: December 07, 2005 - 08:26:36 AM »
My stock 360 4bbl has a set of headers that seen better days. They are slung very low and therefore have several dents and I'm forever having to check them for tightness. I have to make the decision whether to look for a new set of headers or go back to stock manifolds. I like the thought of manifolds, you slap them on, torque them and never think about them again. I do plan on pulling the 360 at some time to rebuild and possibly installing a mild cam but keeping pretty much everything else stock. I'm looking for suggestions on sticking with headers and what brand or going back to manifolds?
Thanks :feedback:
« Last Edit: December 07, 2005 - 09:38:49 AM by basement »
Offline pink panther
Re: Headers vs manifolds
« Reply #1 on: December 07, 2005 - 09:31:24 AM »
Headers definately give you increased horsepower gains, if you plan on a nice daily driver manifolds will do just fine.  TTI has excellent headers, I currently Have Hooker comp headers on my chally and they do seem to be quite low as well.  For me there is no decision I will run headers all day long, as my motor is built pretty strong.
just my 2
« Reply #2 on: December 07, 2005 - 10:02:53 AM »
Headers will definitely give you more power, and if you got back to stock manifiolds, you will have to redo the exhaust pipes as they were probably cut off to fit the headers. It depends on your exhaust system and what kind of shape it's in... maybe you would replace everything from the engine on back???
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #3 on: December 07, 2005 - 10:22:32 AM »
I have stock manifolds on my '72 and always tinker with the thought of headers to open up the exhaust but I want to keep the car stock/stock looking.
Is there a prefered stock manifold you could use that has header like/better flow for the 360?  As stated by pink panther, for a daily driver the manifolds are nice but if you want to better reap the benefits of the cam upgrade the headers might be a more viable option.  Just my 2 cents.
« Reply #4 on: December 07, 2005 - 10:45:56 AM »
TTi are expensive butyou get what you pay for , the fit is great , & they DO NOT habg below the steering so the ground clearance is great as well
 getting a set of Good production manifolds will be expensive also , they are difficult to find & were produced for the 340 from 68-71 only
Offline Carlwalski
« Reply #5 on: December 07, 2005 - 03:44:08 PM »
Headers for sure!!! Headers = Breathing.  :bananasmi tti only way to go as mentioned above.  :thumbsup:
 :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #6 on: December 07, 2005 - 04:08:34 PM »
basement,
   Do you know what brand of headers you have now??? There MUST be a better set available to you. Even though I didn't spring for the big $$$ TTI headers, I have no problem with scraping or anything. I also don't have to tighten mine. Maybe you just got a bad set???  :dunno: Maybe the gaskets are crappy???  I have a set of crushable/ re-usable gaskets made by Percy that do the job well.
Offline mopar-or-no-car
« Reply #7 on: December 07, 2005 - 04:54:38 PM »
This was my understanding that the early exhaust manifolds were as good as headers! but as chryco pointed out they are difficult to find and very expensive!! Good Luck :thumbsup:
Offline Carlwalski
« Reply #8 on: December 07, 2005 - 05:00:29 PM »
 :iagree: That is a good point, Headers over Manifolds are only going to gain hp if you have an aftermarket exhaust system set up.
Some people think headers = hp, in most cases true but some can do bugger all or gain nothing over manifolds without the proper set up.
What exhaust system will you be running?
 :cheers:
Offline basement
« Reply #9 on: December 07, 2005 - 05:21:55 PM »
Presently have a set of Hookers that run into Flowmasters. Not sure of the diameter of exhaust pipe, possibly 2".
Offline N96cuda
    • Kirks Cars
« Reply #10 on: December 11, 2005 - 01:20:01 PM »
You probably have 2 1/4". Regardless of headers or exhaust manifolds, you need to upgrade to a 2 1/2" complete exhaust system. I will be going with headers and a complete 3" system on my factory 6 pack Cuda.
70 Cuda 440-6 Shaker, Auto, Vitamin C, stripe delete, black int. & vinyl top, luggage rack, Magnums, build sheet
71 Cuda conv. 383 4-speed, Rallye red, black top, int. and billboards, 2 complete build sheets
09 B5 blue Challenger SRT-8
www.93cobra.itgo.com
« Reply #11 on: December 11, 2005 - 06:57:49 PM »
sorry, didn't mention I run Hooker comp headers into flowmasters withs 3 "inch tunnels to let them roar!  It is about trial and error until you find what fits your needs, TTI does however make the best, on a dime thiough.
