what makes a TRANS DO THIS
Author Topic: what makes a TRANS DO THIS  (Read 2076 times)
Offline BIG MIKE
« on: December 09, 2002 - 11:33:25 PM »
is a 904- it feels like the the trans is locked up but i can drive forward. it don't shift up and when it hits the shift point it feels like a (jakebrake)or you locked the brakes.
can't go in reverse will stall engine. i put it in neutral and can't push it.
it just happened.
all well i put in another one. i was just trying to get some ideas before i open it up.
Offline oldvamoparfan
  • MOPAR; The only way to go!!!!!!!
Re:what makes a TRANS DO THIS
« Reply #1 on: August 20, 2003 - 10:31:45 PM »
I bought an old Charger that had the same problem.  One of the best trans men in the area says the front clutch is welded up.  I didnt fix it; just used the tail shaft to fix one I broke.
'72 Challenger 360,  '05 Dakota,   04 Town & Country,   '82 Yamaha 650 Maxim
Offline Carlwalski
« Reply #2 on: October 01, 2003 - 07:23:51 AM »
Did you check your fluid level? Could be alot of things.... :o  ??? Throttle linkage, kickdown band,
Hydraulic presure not right, clutches sticking, Valve body stuffing up or leaking......Have you sorted the problem out if so I wouldn't mind seeing what it actually was,  cheers.  8)
« Last Edit: October 01, 2003 - 07:41:12 AM by NZ 440RT »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline BIG MIKE
« Reply #3 on: October 02, 2003 - 11:33:13 PM »
it was the sprag, to many burnouts ???
i did a burnout and about 15min. of driving it started acting up. so i just replaced the trans with an extra one i had. then i tore it down to see the cause.  there was no damage to the housing just looks like the springs compressed and the rollers would not release.
by the way does anybody know were i can get a roller and spring kit for a 904. i saw a couple of places but they had a min. $ amount order that was more than the kit i needed.
« Reply #4 on: October 03, 2003 - 01:23:20 AM »
I can most likely get you one , do you want me to send it from here ?
 The rear sprags are available in& bolt in style which is better & also a square roller style for more bite
