Author Topic: Silly Cam Question  (Read 820 times)
Offline matt63
Silly Cam Question
« on: December 07, 2005 - 08:44:34 PM »
I've got to the "cam install" phase of my 408 engine build and I realize I have no cam key.  You get hung up for the silliest reasons.  I think its a 3/16 x 3/4 Woodruff key (#9?).  Can I just to the hardware store and get one of these or is it special?  I don't see it listed in my Mopar books.
 :pullinghair:
Matt in Edmonton
'68 Valiant
Re: Silly Cam Question
« Reply #1 on: December 07, 2005 - 11:47:18 PM »
I believe any hard key will work as long as it has the correct thickness , the factory key is flat on the rear & curved front of the D shape , Also Comp Cams , any speed shop should have a set of keys so the cam can be degreed if nessisary , the kit will have  a Zero offset key
Offline matt63
« Reply #2 on: December 08, 2005 - 06:14:57 PM »
Thanks Chryco.  The offset sets don't seem to have a plain key so I went to the machine shop that did my block and got one.
Matt in Edmonton
'68 Valiant
Offline matt63
« Reply #3 on: December 10, 2005 - 09:08:49 AM »
It turns out that the key didn't fit as I have a Magnum snout on the Hughes hydraulic roller cam which takes a short key.  I also found out that I need the snout extension adaptor which accepts the fuel pump eccentric.   Oh well - just one more snag.
Matt in Edmonton
'68 Valiant
