Fly wheel saps horsepower
Author Topic: Fly wheel saps horsepower  (Read 1245 times)
Offline 71chmark
« on: December 09, 2005 - 03:40:09 PM »
My friend tells me the heavy flywheel of a manual trans saps horsepower and that I would get more power from an automatic. True?
I may be schizophrenic,
Oldschool
Re: Fly wheel saps horsepower
« Reply #1 on: December 09, 2005 - 04:14:23 PM »
Ok--I'll take a shot at this one.  This is a broad question and I am going on the assumption that this is concerning a street type car.  Generally speaking, the factory utilizes a relatively heavy flywheel.  This is to make the car operate smoother.  The heavy flywheel does take a little more HP to turn it up, BUT the car takes advantage of this heavier flywheel.  A heavier flywheel stores more energy than a light one. This energy helps keep the car from bogging down on takeoff and in between gears.  The weight keeps the momentum of the engine/flywheel up and it doesn't decelerate as quickly. If this momentum wasn't there, the car would be more "herky=jerky".  Drag racers use lightweight flywheels because they don't take as much HP to spin up, BUT the racers don't need smoothness.  They leave under full throttle and shift gears as quickly as possible.. They have alot more horsepower and less vehicle weight to move.  Generally speaking, in most street/strip applications, an automatic, (with stall convertor and shift kit) is quicker. It shifts quicker and has one less shift in the quarter mile. Of course there are exceptions to this generality. Hope this helps a little.  :burnout: ..............Oldschool
« Last Edit: December 09, 2005 - 04:52:15 PM by Oldschool »
« Reply #2 on: December 09, 2005 - 04:18:35 PM »
Oldschool,
   As the Guinness beer commercial says, "brilliant!!!"   :ylsuper: That was a great explanation.
Offline lemurfart
« Reply #3 on: December 09, 2005 - 04:47:00 PM »
that was very informative thank you
Dak(will keep stock flywheel on because he likes smooth)
2008 Ducati 1098 - Flat Black :)
1972 Dodge Challenger 340-4-4speed pistol
« Reply #4 on: December 10, 2005 - 12:51:27 AM »
 I will also add thet the 4 spd has less internal drag & transmits more power through it than an Auto tranny will
 BTW even going from a 40 lb to a 30lb flywheel makes a big difference in the way the car will launch , losing 10 lbs feels like you lost a cylinder or more !!
Oldschool
« Reply #5 on: December 10, 2005 - 04:55:10 PM »
  :iagree:  One step further---straight cut gears are more efficient than helical cut ones, but are more noisy.  That's why factory uses helical cut gears, but racing trannies use straight cut ones.  :ylsuper:  .......................Oldschool
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: December 11, 2005 - 05:17:16 AM »
Oldschool,
 :iagree:  Oldschool, you make me feel like I'm back in auto mechanic school!  I miss those days!  Excelent explination!
Offline pink panther
« Reply #7 on: December 11, 2005 - 07:57:40 PM »
I think this calls for......................
MEN OLD SCHOOL!   We salute the men of OLD SCHOOL!  ith a little bit of knowledge.....and a lot more brains than half of us...........they continue on as MOPAR FREAKS!  Thanks OLD SCHOOL!
Oldschool
« Reply #8 on: December 12, 2005 - 09:47:00 AM »
  :cheers:
