Anyone know an appx. HP num. for a stock 360ci engine with 4-barrel carb?
Author Topic: Anyone know an appx. HP num. for a stock 360ci engine with 4-barrel carb?  (Read 894 times)
Offline Sukhoi
  • Mr. 3-d
Yes, I'm shallow and i want bragging rights  :smokin:
Anyway, so far as i knoiw, the engine is stock, a 360 ci v-8 with a four barrel carb. the engine did not come with the car originally, the previous owner swappe4d out the 318.
I don't know too much about engine dynamics, so if it isn't possible to get an approximate hp number, then that's cool.
I don't have access to a dynomometer or i'd check it myself. nor am i old enough to go to the strip to get a 1/4 mile time (Age limit is 18)
And besides, I have to be able to smoke the new challenger when it comes out  :bigsmile:
sorry for the acronymn/abbreiviation hell title, i didn't have enough room for everything
and yes, i did seaerch this before posting, didn't get anything
« Last Edit: December 09, 2005 - 11:40:19 PM by Sukhoi »
Re: Anyone know an appx. HP num. for a stock 360ci engine with 4-barrel carb?
« Reply #1 on: December 10, 2005 - 12:55:41 AM »
360s were never built as performance engines , all had poor cams & low compression , so maybe 185 hp & lots of torque
Offline Sukhoi
  • Mr. 3-d
« Reply #2 on: December 10, 2005 - 05:02:49 PM »
That was around what i was thinking. feels that way, too.
thanks
Offline Rob C
« Reply #3 on: December 10, 2005 - 10:12:49 PM »
Depends on the year of the engine really. But there about that and not much more. The good news is a set of good heads with a reduced chamber for a raised comp ratio and a good cam wake these things up nicelt.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: December 17, 2005 - 12:31:21 PM »
The 360 4bbl code E85 was rated at 245hp from the factory. This engine came out in 1974 and had the 340 cam with 8.4 or 8.5 compression and windage tray and roller timing chain.
were a very good engine.
2013 Tige' RZR 343hp
