got a problem
Author Topic: got a problem  (Read 2031 times)
Offline gotacuda23
  • 73 mist green 440 cuda
got a problem
« on: December 10, 2005 - 07:04:53 PM »
on my cuda, the rear tires rub the wheel wells, so im going to put adjustable rear shox on, and was wondering what to go with, gas or air, also, whats a good brand
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: got a problem
« Reply #1 on: December 10, 2005 - 07:59:47 PM »
Does this mean you have the car???
Offline gotacuda23
Re: got a problem
« Reply #2 on: December 10, 2005 - 08:19:29 PM »
nope, not yet, thats just what my uncle told me... i just got off the phone with the guy halling it, and if the snow storm he has been caught up in for the last few gives him a chance, he should be here monday-tuesday  :jumping:
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Re: got a problem
« Reply #3 on: December 10, 2005 - 09:54:30 PM »
Go with a good gas shock.  Parts are only worth what you are will to pay for.  I would check to see that the leaf springs haven't started to sag (common problem).  You can get them rearched at a big rig shop, or for a little more buy new ones (but I don't reccomend super stocks, unless you are just going to drag race this car).  Also check the spring bushings, make sure they are not shot, allowing the rear end to move side to side.  Good luck!! :bigthumb:
{oo/===\oo}
Oldschool
Re: got a problem
« Reply #4 on: December 10, 2005 - 10:00:19 PM »
 :iagree:
Offline 71340RT
Re: got a problem
« Reply #5 on: December 11, 2005 - 06:47:40 PM »
I would also go with gas shocks. If you need to have your sagging springs corrected I would go with new springs from espo Springs N Things as they can give you a 1 inch over stock or 2 inch over stock to keep the car wheel wells away from your tires. I ordered my new springs from them last tuesday and they were delivered to my door on Friday.  I had them in 3 days and they told me they make their springs to order and this way you always get a matched set for the same ride height side to side. I bought the 1inch over stock spring to raise the rear end of my 71 Challenger a little bit higher than stock. If you go with them they have a toll free number 1 800-903-9019.
Jeff
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Re: got a problem
« Reply #6 on: December 12, 2005 - 03:16:50 AM »
Jeff
 :iagree: That's the path I took. Then you can use any kind of shock, and not have a harsh ride. Changing out those springs is a dirty job though.  :pullinghair:
Offline Hopalong
Re: got a problem
« Reply #7 on: December 12, 2005 - 11:53:29 AM »
 :thinkerg:  Could just be funny offset wheels.  If they are the ones in the photos, check the back spacing.  Just 'cause they bolt up doesn't mean they're right!
{oo/===\oo}
Re: got a problem
« Reply #8 on: December 12, 2005 - 03:16:07 PM »
That's a good point about after-market wheels. Maybe not enough backspace? Do you know the rim and tire size?
Offline 360 'CUDA
Re: got a problem
« Reply #9 on: December 13, 2005 - 10:07:14 PM »
maybe some minor trimming would fix it.  Never do airshocks though  :crazy:
Those are the first things to hit the trash when I get a new car in
Offline gotacuda23
Re: got a problem
« Reply #10 on: December 25, 2005 - 09:27:26 PM »
i think the problem im running into is the back tires are too WIDE, and they rub the wheel well, so im need to life the back up a little so they done rub
Re: got a problem
« Reply #11 on: December 26, 2005 - 01:22:35 AM »
or the rear rims have the wrong offset  ,possibly swapping rear rims will tuck the rear tires an extra 1/2" or so
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: got a problem
« Reply #12 on: December 26, 2005 - 05:46:18 PM »
I had the same problem with my aftermarket wheels.  All better now that I went back to the rallye wheels.  Check your backspacing, I bet that is the problem.
Offline gotacuda23
Re: got a problem
« Reply #13 on: December 27, 2005 - 01:53:27 PM »
yay!!!! i figured it out... i was showing it to a local chevy restoration guy, and he told me the problem... i need to get different rims, and jus move  them in a little, just like some of you said!
thanks guys
Offline wart1de
    • Vivah
Re: got a problem
« Reply #14 on: December 28, 2005 - 04:18:50 PM »
You let a chebby guy touch your cuda??  :nono:
 :lol:
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
