Author Topic: oil pump  (Read 563 times)
Offline justin16440
oil pump
« on: December 12, 2005 - 04:15:19 PM »
Chryco I was reading a post on someone engine and you favored a high pressure oil pump instead of high volume  Just curios why it is a better choice thanks justin
Offline BIG MIKE
Re: oil pump
« Reply #1 on: December 12, 2005 - 05:10:37 PM »
the high volume pumps have pumped to much that it starved of oil(all the oil reserve is up in the top).. that floods the valves...
Offline wart1de
    • Vivah
Re: oil pump
« Reply #2 on: December 12, 2005 - 06:06:43 PM »
Also puts more stress on the oil drive
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Re: oil pump
« Reply #3 on: December 12, 2005 - 08:58:49 PM »
with a stock pan on a long pull you can take out main or rod brgs due to starvation , with a 12 qt pan I doubt there would be a problem , I ran mine for ten years at 7200 RPM with a HV & a 12 qt pan
