Author Topic: is 10.34-1 too much compression for todays gas?  (Read 2547 times)
Offline moparnut
    • My Photo's
« on: December 12, 2005 - 08:12:53 PM »
I have the opportunity to get a slightly used set of trw L2295 pistons at a good deal.With 88cc heads compression would be 10.34-1 is that too much and how much can i take off with different head gaskets and which ones?thanks in advance Chryco,lol
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Oldschool
Re: is 10.34-1 too much compression for todays gas?
« Reply #1 on: December 12, 2005 - 08:38:24 PM »
My Hemi is 101/2 to one.  They are a little more tolerent of compression than wedges, but I run pump gas all day long with no problems  :burnout: Oldschool
« Reply #2 on: December 12, 2005 - 09:05:29 PM »
yes & no
 the domes can be trimmed off to lower compression , or you can use a thicker head gasket to decompress a little
 it really depends on the cam , a short duration cam will build a lot of cylinder pressure & puts the powerband low where it will ping , a long duration cam will do the opposite & should be Ok & generally will not ping in the 2500 rpm range where the engine will make power , you will also need a loose converter with 2800 stall so no load is on the engine where it would ping
 I don`t like the 2295 piston for flame travel though
Offline moparnut
    • My Photo's
« Reply #3 on: December 12, 2005 - 10:54:02 PM »
thanks,think I'll pass on those and wait for another deal :burnout:
Offline Rob C
« Reply #4 on: December 14, 2005 - 06:38:46 PM »
Good answer Chryo.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
