Body side moulding
Author Topic: Body side moulding  (Read 2625 times)
Offline bentpshrods
  • Almost there, Boise Id.
Body side moulding
« on: December 17, 2005 - 04:01:20 PM »
A few questions: My cuda originally came with a rubber moulding (held on by an adheasive) that ran down the side of the car at the belt line. I thought it was just an add on by the previous owner and removed it. Now as I begin restoring things back to original I was wondering if this option is rare. What was the code for it, and is this trim piece hard to find. thanks Doug
Offline Carlwalski
Re: Body side moulding
« Reply #1 on: December 17, 2005 - 05:20:12 PM »
M33 Is the fender code for Moldings. I have always thought the moldings were attached with rivets, not with adhesive?  :dunno:
My Challenger is an original body side molding car but I decided (late) not to put them on (a decision I'm am glad I made).
My car came with aftermarket ones, the originals were removed sometime in it's life.
Someone replaced them with adhesive moldings that didn't look correct.....
As for how hard they are to find, pretty tough to find a decent set.
Try www.ebay.com I got my factory originals from www.tonysparts.com
Cheers,
NZ440R/T
I've attached some photos of my Challenger prior to restoration.
« Last Edit: December 17, 2005 - 05:23:36 PM by NZ440R/T »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
BH23cuda
« Reply #2 on: December 17, 2005 - 06:03:42 PM »
My 70 came with factory black vinyl body side moldings. These were held on with adhesive - no holes or clips.
Fender tag VX5 for his option.  There were also pinstripe tape lines on either side of the molding.
Offline Carlwalski
« Reply #3 on: December 17, 2005 - 06:20:40 PM »
True, my fender read V5X also sorry, don't know what the body side moldings are for M33?  :dunno:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: December 19, 2005 - 03:36:46 PM »
Wierd, M33 and V5X are both noted for body side molding but on the decoders I tried they don't differentiate it.  As far as the V5_ code, the X was for black.  I guess there were numerous colors you could have gotten so check your codes, bentpshrods.  Don't know how many of these different colors relate to the V5_ option.
V4* 71 Vinyl Canopy Roof (See V1* for Colors)
V5* 69-71 Body Side Molding
V6* 69-71 Longitudinal Stripes
V7* 69-70 Accent Stripes
V8* 69-71 Transverse Stripes
V9* 70 Bumble Bee Stripes
V9* 71 Longitudinal Stripes
V5* thru V9* Missing digit represents color choices
A- Gunmetal
B- Light Blue
C- Plum Crazy
D - Dark Blue
E - Bright Red
F - Green
H - Trans Am Black
J - Chartreuse
K - Go Mango Orange
M - Magenta (1970 Only)
M - Burgundy (1971 Only)
R - Red
T - Tan
V - Orange
W - White
X - Black
Y - Yellow
8 - Delete
I have the V5X on my '72 Challenger Rallye.  With this code, there is a possible delete, in my case my car didn't get the side front fender louvers and it's a real JS car.  Not sure either if it's becuase mine was an early production (8/17/71) and I've seen some Dodge promo pics that look similar to my car, with bodyside mouding but no fender louvers.  I dunno. :dunno:
Offline Cannibal94
« Reply #5 on: December 19, 2005 - 04:15:05 PM »
Here is a pic of the side moldings that were on (falling off) of my car prior to restoration (obviously)  :biggrin:
I don't like the looks of them one bit.....although it would save you from door dings!
« Last Edit: December 19, 2005 - 04:17:20 PM by cannibal94 »
Offline bentpshrods
« Reply #6 on: December 19, 2005 - 08:46:44 PM »
Thanks for the pics and info. My build sheet nor my fender tags have the V5X code--the fender tag has M31 which I have found listed as 71 only--belt and hood molding. Don't know what the difference is between this and V5X?  or what hood molding would be. Lots to learn.  Guess I"ll make a decission to put them back on or not after I get it painted.
Offline mopar-or-no-car
« Reply #7 on: December 19, 2005 - 11:22:45 PM »
I have those mouldings on the side of my 71 chally too and the code on my fender tag is V5X also! good luck on your decoding!  Mine are also the stick on type. The previous owner of my 73 put them on that one but he had them pop rivited on they looked real nice and had reflectors in each end that matched the side marker lights! just a thought! and yes they do cut down a little on door dings but a real little
Offline Carlwalski
« Reply #8 on: December 19, 2005 - 11:50:19 PM »
Cool, thanks for clearing that up Barry.  :thumbsup:
Alaskan_TA
« Reply #9 on: December 19, 2005 - 11:53:23 PM »
I goofed! Just a little, but here it is with fresh images.  :wave:
These may help?
V5 moldings would have run down the area about halfway up the body. If the car is not coded for them they were added later.
The M31 belt moldings ran across the door tops below the windows.
My aplogies for writing on your car.  :wave:
