Author Topic: OK my turn-truck questions.  (Read 914 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: December 18, 2005 - 05:47:41 AM »
I am also thinking about buying a truck in a month or so as the old Neon just hit 112k and I`m getting worried about that 4 cyl giving out,anyone know how long the 2.0 motor is good for?My current plow truck is an `85 Ramcharger which isn`t that great for towing with the short wheel base and I`d prefer a p/u bed.From reading the other truck posts I will be looking for a 3/4 ton 4x4 for plowing and towing.I do occasional local towing but would like to tow the `cuda to Carlisle on an open trailer.my limiting factor is money and I don`t want a big payment so I will be loking for either an older `72-92 model or poosibly a `93-95 or so model.Gas mileage is more of a concern than raw power as it will share daily driver duties with the Neon.So,questions are-
Pros and cons of older versus newer model Rams,should I spend the extra money for a newer one or will an older model be fine?
I`ve never had one or know much about desiels so I am leaning towards a gas engine,pros and cons of running a desiel as far as maintenence etc. and for plowing?
Any year/model/engine/transmissions to look for or avoid when searching the want ads?
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Re: OK my turn-truck questions.
« Reply #1 on: December 18, 2005 - 12:13:30 PM »
If you can get a good cummins 95-97 are the Best , pre 24 valve , don`t worry about milage too much the drivetrain is good for approx 1,000,000 miles properly maintained , the auto trannys need to be rebuilt before that though , thye give awesome power & milage , the front ends are the weak point with poorly designed control arms & panhard & stabilizer links
 Myself & a number of friends have bought diesels & we were all sceptical , but after owning them for a few weeks none of us will go back to gas , , the Cummins is awesome  :burnout:
« Last Edit: December 18, 2005 - 12:26:43 PM by Chryco Psycho »
Offline dimples
  • (dodgetkboy78)
    • American car and truck forums
« Reply #2 on: December 18, 2005 - 02:34:57 PM »
Or, the older 318/360 powerd trucks, in the 72-78/9 range, are good.
Don't get e 4x4, unless you really need one, for maintenance pourposes.
Offline torredcuda
« Reply #3 on: December 18, 2005 - 03:08:02 PM »
How about the older diesels?There`s a `91 W250 diesel with plow for $2500 in the local want ads.
Jeff
« Reply #4 on: December 18, 2005 - 03:11:24 PM »
I have an 89 , it is a great truck
 the weak link with them is the usless getrag tranny 5 spd man , other  than that they are Tough trucks & easy to get parts fro as that body was used from 71 - 93
Offline torredcuda
« Reply #5 on: December 18, 2005 - 06:05:46 PM »
Anything to look for when checking out a diesel as they all sound like they have bad rod knock to me?  :roflsmiley:
Jeff
Offline dimples
  • (dodgetkboy78)
« Reply #6 on: December 18, 2005 - 09:09:17 PM »
Oil leaks.
Color of coolant.
Clutch/tranny operation.
Smooth idle. (No missing/skipping/8 cycling)
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #7 on: December 18, 2005 - 09:14:57 PM »
Color and quantity of smoke under acceleration.
2013 Tige' RZR 343hp
