Author Topic: Where to relocate the starter relay?  (Read 1244 times)
Offline rusty dodge
  • 74 challenger 440-727-3:55
« on: December 18, 2005 - 11:29:45 AM »
Can someone recommend where to relocate the starter relay?
I will be putting the battery in the trunk. The underhood battery location is deleted, and the mounting holes for the relay were also deleted while in the body shop. I've seen others done with the wiring - battery relocated, but i have'nt noticed where the starter relay is moved to.
Thanks
Re: Where to relocate the starter relay?
« Reply #1 on: December 18, 2005 - 11:59:38 AM »
I generally mount it on the firewall relatively close to the starter , then run the positive cable [ I use welding cable] from the trunk to the starter , then use a short battery cable from the starter up to the starter relay
