Author Topic: Exhaust Question ??  (Read 2019 times)
Offline cjm
  • 70 Cuda - In Progress.....
Exhaust Question ??
« on: December 19, 2005 - 08:12:53 AM »
What is better ---  a "X" pipe or an "H" pipe for a 70 cuda 383hp....   And why ???
Re: Exhaust Question ??
« Reply #1 on: December 19, 2005 - 09:57:53 AM »
Both are good, but I was told the "X" configuration would be a little better. I guess because the exhaust wouldn't have a 90 degree bend to go through. Hence, easier flow to the other side.
Offline 71340RT
« Reply #2 on: December 19, 2005 - 11:33:14 AM »
The tests that have been done show the X pipe is better as the lines are smooth with no turns. I think is was mopar muscle that had a article awhile back on which would flow better.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline cjm
« Reply #3 on: December 19, 2005 - 11:59:44 AM »
Thanks for the responses. But wouldn't the exhaust flow better if the system did not have either pipe? What is the advantage of flowing to the other side? Is it because of the firing order (having 2 cylinders on the same side firing in a row "twice" (8+4), (5+7))????
Offline Belltone85
  • 1973 Dodge Challenger 360 Crate Motor, Slap Stick
« Reply #4 on: December 19, 2005 - 01:02:47 PM »
well from what i understand is that with an x-pipe or h-pipe the exhaust mixes and creates an even flow of exhaust, where as if you have neither than one side could flow more than the other.
Offline hemi71
« Reply #5 on: December 19, 2005 - 06:33:12 PM »
Crossover pipes even out the exhaust pulses in the pipes, making for a better "scavenge" effect in the exhaust system.
« Reply #6 on: December 20, 2005 - 12:17:08 PM »
any back pressure at the mufflers has the option of taking the path of least resisitance , so yes pressure in the system is reduced , this increases Scavenging at the heads which is the biggest effect on cylinder filling
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #7 on: December 27, 2005 - 12:18:16 AM »
The stock exhaust for the 1970 440-6 did not have a crossover at all..did it? :dunno:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
« Reply #8 on: December 27, 2005 - 01:11:27 AM »
a stock 440+6 came with a H pipe system , X pipes are a recent incarnation / improvement on the old H pipes
