Door sagging on my 71 Challenger convertible
Author Topic: Door sagging on my 71 Challenger convertible  (Read 5262 times)
Offline Cannibal94
Re: Door sagging on my 71 Challenger convertible
« Reply #15 on: December 20, 2005 - 09:27:45 AM »
Should the springs be put in?  What do they do?  Are they original or a add-on?
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #16 on: December 20, 2005 - 09:46:22 AM »
They are a part that should be present.  On the lower hinge, you will notice two rollers.  The rollers are not smooth, but ribbed.  The rollers roll across the the spring to provide stop points for the door so it doesn't just swing back and forth freely and slam in to another car or back on you.  New springs will make the door feel really stiff to open and close at first when they make contact with the rollers.
Offline Cannibal94
« Reply #17 on: December 20, 2005 - 10:29:32 AM »
Only on the Drivers door correct?  I always thought that my passenger was missing parts cause it never held open.  I checked on blue71cuda's car one day and his was the same way.  I assumed that was how it came from the factory.  Is that not right?
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #18 on: December 20, 2005 - 11:30:34 AM »
Should be on both door as far as I know.  I have both.
Offline Cannibal94
« Reply #19 on: December 20, 2005 - 01:16:31 PM »
I will have to check out mine now when I get home.....(Im at work hehe).....and see what setup I have.  I am really curious if I even have the s springs in there.   :dunno:
Offline Cannibal94
« Reply #20 on: December 21, 2005 - 11:13:29 AM »
Well.....the passenger door needs adjusted to shut more...as far as sagging.....not too bad.  The drivers door on the other hand is sagging and needs adjusted.  There is no "S" spring on the drivers side (fell off?)  So I guess I need to buy the "delux" kit that comes with the springs.  Replace all the pins and bushings and springs, hopefully that will solve the problem.  :dunno:
Offline JCWCuda
« Reply #21 on: December 21, 2005 - 04:19:45 PM »
That is how i would approach it ,adjusting with partially worn out hinges will only be temporary fix ,these doors are to heavy for the hinges and do wear them out rather quickly. I don't think you should to much trouble doing it yourself.
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
Offline sccarts1
« Reply #22 on: December 21, 2005 - 11:28:53 PM »
all you need is a good drill bit of correct diameter (cobalt) & asmall ball peen hammer.  the doors on my project fell 3" & now they close like new.
Offline Cannibal94
« Reply #23 on: December 22, 2005 - 07:25:48 AM »
Do you know the exact size of drill bit to use?
Offline sccarts1
« Reply #24 on: December 23, 2005 - 07:37:40 PM »
no but you can  measure the bushing with a caliper.
