3-speed manual to A-833 4 speed.
Author Topic: 3-speed manual to A-833 4 speed.  (Read 1471 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: December 20, 2005 - 10:48:37 AM »
I's it hard the do a trans switch from 3 speed manual to 4 speed manual on a Cuda?
Do I use the same bellhouse etc?? Are the pedals the same???
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: 3-speed manual to A-833 4 speed.
« Reply #1 on: December 20, 2005 - 12:20:27 PM »
the pedals are the same , I belive the Belhousing is the same , depending on the diameter of the input brg retainer the rest will bolt in
Offline widing'cuda
« Reply #2 on: December 20, 2005 - 12:45:25 PM »
Ok, so it's a bolt on job. The reason I'm asking is, I'm think of buying a 3 speed manual and converting it to a 4 speed, as it's cheaper to buy then a 4 speed car.
« Last Edit: December 20, 2005 - 01:01:38 PM by widing »
« Reply #3 on: December 20, 2005 - 12:54:37 PM »
good idea
Offline Killer_Mopar
« Reply #4 on: December 20, 2005 - 01:08:23 PM »
My father and I just converted his 3-speed small-block challenger to a 4-speed this summer. It is a bolt in operation, you will of course need a new shifter mechanism and the only hiccup we had was the bolt holes on the bellhousing....they were there, but since they sat outside the 3-speed mounting holes they were full of grime so make sure you clean the threads up. I also know that it is a bolt in operation for big blocks because my 383 Challenger was originally a 3-speed and is now a 4-speed.
Offline widing'cuda
« Reply #5 on: December 20, 2005 - 01:12:32 PM »
Thanks for the info guys
