Hemi - Aluminum or Cast Iron?
Author Topic: Hemi - Aluminum or Cast Iron?  (Read 2269 times)
Offline cudabuyer
« on: December 20, 2005 - 02:55:17 PM »
Trying to decide if 170 lbs is worth $2100.00 extra for a 700 hp hemi build.
70 Dodge Challenger Convertible 6.1 Hemi
Re: Hemi - Aluminum or Cast Iron?
« Reply #1 on: December 20, 2005 - 02:58:29 PM »
the Alum blocks definatly have more strength & are easier to repair
 I guess it depends on your budget
« Reply #2 on: December 20, 2005 - 04:45:13 PM »
   :iagree:  Also, if you are capable of 700HP, do you care about 170 extra pounds???  Maybe if you are a serious drag racer. What are you using this car for?
Offline cudabuyer
« Reply #3 on: December 20, 2005 - 06:25:37 PM »
A lotta show and a lotttttta gooo.  Seriously even the builder says it is overkill.  My thoughts on the aluminum is less weight on the front end.
I think that probably 500 - 550 hp is more than enuff
Oldschool
« Reply #4 on: December 20, 2005 - 06:31:31 PM »
Cuda,
Have you thought about the possibility of an iron block with aluminum heads?   :thinkerg:  Kinda splits the difference on the weight issue and still gives the power of the aluminum heads. It's also cheaper than the all aluminum setup.  That's the engine setup in the Oldschool ride.  775 horsepower and the car weighs 3254 lbs--including the roll cage.  Just a thought.   :cooldancing:  ....................Oldschool
Offline cudabuyer
« Reply #5 on: December 21, 2005 - 08:11:08 AM »
the extra $2100 would help defray costs of headers, radiator swap, etc etc etc.
kudakidd
« Reply #6 on: December 21, 2005 - 10:52:13 AM »
I wish I was faced with such tough decisions! :biggrin:
Offline cudabuyer
« Reply #7 on: December 22, 2005 - 08:13:48 AM »
Well that tough decision is still under approval from the wife and Santa.
More 2 come later
« Reply #8 on: December 22, 2005 - 10:51:58 AM »
what Rpm are you planning to make 700 hp at ,
 which Iron Hemi block are youy looking at buying ?
Offline cudabuyer
« Reply #9 on: December 23, 2005 - 05:42:48 AM »
Speedomotive builders in Calif
« Reply #10 on: December 24, 2005 - 12:02:15 AM »
Im not sure what the supply is like from Mopar for the iron mega block or what HP they will take , alum blocks will withstand 2500 hp range though
