Author Topic: 408/416 Guys, What carb are ya running?  (Read 951 times)
Offline dst
  • Negated Identity Construct
« on: December 20, 2005 - 06:32:38 PM »
What carb are you guys running on your 408 or similar engine?
I am trying to decide which carb to go with for my 10.3 CR Edelbrock head steet 408.
Opinions welcome!  :thumbsup:
There are those who have fallen and those who are going to fall.
Re: 408/416 Guys, What carb are ya running?
« Reply #1 on: December 20, 2005 - 10:00:57 PM »
minimum of double the CI
with larger cam & good heads 850 woul dbe in line or the 750 CFM dominator if you have the intake for it
Offline matt63
« Reply #2 on: December 21, 2005 - 06:27:15 PM »
I have to make the same decision in the spring.  I'm thinking a 750 or 800 although I'm undecided on the rest.  Perhaps I'll try a good ole Holley this time as I wasn't thrilled with my last Speed Demon.  If my budget is shot by then I'll try the Edelbrock Thunder Series 800.
Matt in Edmonton
'68 Valiant
Offline Tom Quad
« Reply #3 on: December 21, 2005 - 07:12:44 PM »
use a six pak, it's the only way to fly
« Reply #4 on: December 21, 2005 - 10:47:03 PM »
6 packs do work great .... just a touch pricey
Offline dst
« Reply #5 on: December 22, 2005 - 01:28:24 AM »
I. Would. Love. A. Six-Pack!
But can not afford it and can't save up, need car out of garage ASAP.
According to my budget a four barrel like Holley/Demon/Proform is the way to go.
Those animated .gif's are annoying...
Offline bennydodge
« Reply #6 on: December 22, 2005 - 06:44:55 PM »
I'm running a 750 Holley HP double pumper with my E-head 416. Throttle response is very fast. Hits real hard. I'm very impressed with the HP line of carbs. After I port the heads and go to a bigger cam I'll probably run the 950 version.
1973 Dodge Rallye Challenger 340(416 stroker), 727 ,3.23 SG, 76,xxxmi.
2010 Ram 3500 CC Dually 4x4, Cummins, loaded
2015 Challenger R/T classic B5 5.7 8spd
