Cam Question
Author Topic: Cam Question  (Read 1554 times)
Offline R/T
  • Johnson City TN
Cam Question
« on: December 22, 2005 - 05:01:00 PM »
If you could break this down to something less technical it would be a big help
Stage 4: 3200-6500 RPM
The Stage 4 cams are racing cams designed for street high performance and limited circle track and drag strip racing use. They have a rough idle quality with significantly improved mid to high range torque and power over stock cams. Works best with modified engines with compression ratio of 10.0-1 to 11.0-1. Headers, dual exhaust, 4 barrel carburetor, 3.70 to 4.60 gear ratio, and 2500 stall converter required. Significant vacuum loss to be expected and may be to low to run power brakes and accessories normally.
Part #  Cam Type   Idle Quality   Power Range   Valve Lift Int/Exh   Dur@050 Int/Exh
E941P  Hydraulic       Rough         2200-5400                .480 .480               230° 230°
Adv Dur  Int/Exh     Lobe Center Int/Exh       Lash Int/Exh
            292° 292°                  107° 111°            Hyd Hyd
The cam is an Elgin Pro Stock . Also how would this cam be for street use only?  Can I  use 3.55 gears or should I go bigger since it will be street use. Engine is a 440 10.5 to 1 compression  and I am running a Holly 770 cfm  Street Avenger.
 Sorry for the long post
  P.S. This cam is already in , it came with my car as the guy I bought it from had just had the engine built
« Last Edit: December 22, 2005 - 05:08:56 PM by 71 r/t »
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
Offline matt63
Re: Cam Question
« Reply #1 on: December 22, 2005 - 06:36:48 PM »
230 @ 050 doesn't sound too radical as the MP292/509 cam is 248 I believe.  I ran that cam on the street in a 383 with no problem.  My guess is that 230 deg duration is as much as you can run with stock heads and 3:55s assuming you have headers and a good intake.  The rpm range of 3200-6500 is a bit of a concern though.  For the price of a new cam and some gaskets though I would get what matches your requirements.  Perhaps Chryco can add to this.  Just my $0.02.
Matt in Edmonton
'68 Valiant
Re: Cam Question
« Reply #2 on: December 23, 2005 - 12:20:33 AM »
Definatly better cams out there , this is a slow ramp cam & seem to have a fair amout of overlap which narrows the powerband & makes it idlel poorly, this cam is designed to be kept in a narrow RPM range to work best
for comparson the Engle K58 also has 230* @ .050 but only has 276 * advertised duration + it has more lift @.520 & a wider powerband from 2000-5800
you will need 3.55 gears minimum & I doubt you will really like the ca on the street
 the other problem I see is the 770 cfm avenger is too small for a 440
Offline R/T
  • Johnson City TN
Re: Cam Question
« Reply #3 on: December 23, 2005 - 07:45:39 AM »
Hey, thanks for the replies. I will be asking more questions later on as I get into the car more. I don't like this cam and will be looking for a good street cam later.  This is my first BB Mopar, I have always had SB but i am finding out that they are a world of difference
Hemis and Harleys
Re: Cam Question
« Reply #4 on: December 24, 2005 - 12:03:51 AM »
Yes they are ... Ask away
