Author Topic: rear shock removal  (Read 1367 times)
Offline MoparMatt383
  • Member as of March 2004
rear shock removal
« on: December 23, 2005 - 04:14:18 PM »
I tried to remove the old rear shocks on my barracuda today.  The bottom bolt broke so it was easy to get that off.   :stomp:  Then I was able to get the nut off for the top of the shock, but could not get the bolt out to remove the shock for anything.  I tryed to pound it out and I tried to turn it out, but it just would not budge.  Its as if the bolt and shock have become one, which would not surprise me.  Any ideas because I am out of them?
Matt
Too many projects and nothing gets done.
Re: rear shock removal
« Reply #1 on: December 23, 2005 - 04:46:14 PM »
There is a metal sleeve that the bolts slides through. Chances are, everything is nice and rusted together now. Any chance you can slide a large flat blade screw driver up there where the nut was, and try to use the screwdriver as a lever to force the bolt out the other side?
« Reply #2 on: December 23, 2005 - 05:10:58 PM »
I dont think so Mek.  I was trying that and there is very little room to get any decent leverage.
Matt
« Reply #3 on: December 23, 2005 - 11:44:42 PM »
penetrating oil & heat
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: December 26, 2005 - 10:13:30 PM »
Bottom bolt broke? You will need a new spring plate as this is a stud welded into the plate.
2013 Tige' RZR 343hp
