Author Topic: windshield trim retainer clips for Cuda's  (Read 1021 times)
Offline miketyler
    • www.miketyler.net
« on: December 24, 2005 - 07:13:17 AM »
Is there a lot of variation in these between 70-74 Cudas? When I replaced the clips on my back glass I found that what I had was different then what was advertised in the Mr. G catalog for a 72 Cuda. I ordered the closest match to what I had and all fit pretty well. Now I am preparing to put the front glass in and am seeing the same thing. I would like to save a few dollars and buy these off of Ebay but they appear to be a little differenet than mine. Here are pics of the two for comparison. The lower is what supposedly fits all Cudas and Challengers front and rear glass. There are differences but I suppose the main one is going to be the distance from the center of the retaining pin to the trim retaining lip. Has anyone used the below type before?
« Last Edit: December 25, 2005 - 06:06:57 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline RusTy/SE
  • Just havin' fun
Re: windshield trim retainer clips for Cuda's
« Reply #1 on: December 24, 2005 - 08:47:50 AM »
mike i've had good results as far as the clips being close to original at  www.rtspecialties.net  as they had exact repros of the clips that retain the SE trim to the tail panel. I checked their site and found a pretty close match for your original clip under the Window Trim and Hardware section.
http://www.rtspecialties.net/rtphotos/1000043a.jpg
since you're already in to Mr. G's have you contacted them? maybe a mix-up when your order was filled?
« Last Edit: December 24, 2005 - 09:07:33 AM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline RUSTY Cuda
  • One big step foward!
« Reply #2 on: December 24, 2005 - 07:38:48 PM »
Got mine from year one, they also look like the originals. Rich
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: December 25, 2005 - 05:17:17 AM »
Like anything there are different manufacturers but you are correct in that the only thing that will affect how they work is the distance from the screw or stud location to the lip where the moulding snaps on.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
