Author Topic: shaker hood from flat  (Read 2418 times)
Offline moparnut
    • My Photo's
« on: December 25, 2005 - 04:35:54 PM »
I know this has been discussed many times,is there a website or specs for turning a flat hood into a shaker?These guys want a flat core so they must be making them from a flat hood and makin a killin doing it
http://cgi.ebay.com/ebaymotors/Shaker-Hood-Cuda-Challenger-E-Body_W0QQcmdZViewItemQQcategoryZ10076QQitemZ4599612009QQrdZ1
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Re: shaker hood from flat
« Reply #1 on: December 26, 2005 - 01:40:15 AM »
to do it right you need to have a correct 70-71 hood with the triangle star on the front of the center ridge
Offline xblade
« Reply #2 on: December 26, 2005 - 06:36:47 AM »
What car you want to put the shaker on?
Chryco is right about the correctness, but if your building a street car or drag car I'd use what I had.
I'm in process of converting a hood for my 72 challenger. I'll use a 72-74 flat hood because it was a great price and the painted hood trim was in excellent condition. About the diminsions I cant help you, I tried to get em here with no luck.
Offline moparnut
    • My Photo's
« Reply #3 on: December 26, 2005 - 09:02:57 AM »
Not sure just throwing around ideas,maybe use the flat hood on my GC but probably dont want to spend the money doing it,plus I'd like to keep the original hood,I have a cuda hood going on it
Offline 71chmark
« Reply #4 on: December 26, 2005 - 09:22:04 AM »
Checkout www.harmsauto.com.  I expect you could make a shaker hood for around $1500. Rough estimate.
I may be schizophrenic,
« Reply #5 on: December 26, 2005 - 02:10:49 PM »
I should clarify thet the hood I was reffering to is the Challenger hood , I`m not sure if the Cuda flat hood was unique in 70 -71 compared to later 72-74 hoods
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #6 on: December 26, 2005 - 04:28:02 PM »
www.shakerhood.com builds the kits to do it yourself.
2013 Tige' RZR 343hp
Offline Green Drop Top
« Reply #7 on: November 22, 2006 - 03:24:10 PM »
Thank you for the referals guys  :cheers:
*BTW, I should add that if you are doing a Challenger conversion there is only one company selling the Challenger conversion kit with the specific Challenger style under brace piece and that is us (www.harmsauto.com) anything else on the market is a generic Cuda style.
Concerning correctness on a factory appearing Challenger hood, yes, as some above have mentioned above the early style hoods with the Dodge tri-star emblems on the nose are what almost all 70-71 Challenger Shakers hoods originally had. However.....There were a very few 71 cars built using the later flat front style Shaker hoods, these hoods hit the production line near the end of 1971 model year production run and were sold for many years as over the counter replacements as well. So, technically, for a 71 clone car anyway, either style hood would be acceptable and either one looks nice once done.
 :2cents:
Offline EVIL72
« Reply #8 on: November 22, 2006 - 03:52:56 PM »
  I don't think i've ever seen anyone put a shaker hood on a 72-74 Challenger, anyone got any pics?
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
« Reply #9 on: November 22, 2006 - 03:59:13 PM »
I cant believe that I threw away flat hoods for both (many years back) DOH.... :crying:
Hurry,, Duane the tub,,I'm Dwouning....
Offline 360 'CUDA
« Reply #10 on: November 22, 2006 - 04:07:19 PM »
I just kept stacking them in the corner,,,  I have 6  :naughty:
4 of them for 1970
Offline 360 'CUDA
« Reply #11 on: November 22, 2006 - 04:17:04 PM »
As far as I can tell there are 3 different flat hoods from 1970 to 1974 on Barracudas
1- No holes for Plymouth emblem and no crumple zones -early 1970
2- No holes for Plymouth emblem with crumple zones ---later  1970
3- Holes for Plymouth emblem with crumple zones  all 1971 to 1974
Keep in mind those emblem holes are stamped into the metal top and bottom and would be really hard to reproduce on a '70 hood
« Reply #12 on: November 22, 2006 - 04:42:22 PM »
Quote
I basically agree with you on this, I would'nt really call the late 70 hood without emblem holes a sepperate style though, it's the exact same hood as the later style hood with crumple zones, they just  started adding the emblem access and pin location holes shortly after production started, otherwise every other detail of the under hood and upper hood skin structures are exactly the same as far as the style with crumple zones goes.
Offline 360 'CUDA
« Reply #13 on: November 22, 2006 - 06:45:46 PM »
It's not like they just drilled three holes to add the emblems though. I think if you were restoring a real 1971 Barracuda but had just a '70 hood it would be really hard to make the access look right without damaging the metal above.
Wouldn't it?
I just thought I would give the exact details on every possibility
« Reply #14 on: November 22, 2006 - 08:41:55 PM »
Quote
I agree, no problem with that at all!  :cheers:
*Yes, cutting the pin access holes in the under structure is a challenge but I've done it and it came out fine, it's really just a matter of "measuring twice and cutting once" (with the right tools)
 :2thumbs:
