correct carb for '70 383hp for CA?
Author Topic: correct carb for '70 383hp for CA?  (Read 7971 times)
Offline rm23j8g
« on: December 27, 2005 - 08:52:58 AM »
I'm trying to find the correct carb for my "new" '70 Challenger RT/SE , automatic 383 with A/C and N-95 ECS (California) emission system.
There is no build sheet, as it's an LA built car, so I don't expect to find one. The carb on it now is an AVS for some kind of mid '70's Ford.
I've run across some conflicting info on the correct original carb for this application.
Does anyone else have a '70 383hp, automatic California with air car with the original carb on it?
Most resources are showing a Carter AVS 4734, but I'd sure like to verify this.
Thanks
Guy
« Last Edit: December 27, 2005 - 09:01:12 AM by rm23j8g »
Re: correct carb for '70 383hp for CA?
« Reply #1 on: December 27, 2005 - 10:16:42 AM »
a friend had the exact car but not cali & it lisyed both the AVS & Holley 600 , it ran better with the Holley , I have an AVS from this car listed in the parts for sale section
 I cannot find the ad , I will have to look for the carb to get the number
« Last Edit: December 27, 2005 - 10:22:05 AM by Chryco Psycho »
Offline pandamarie
  • I love YaBB 1G - SP1!
« Reply #2 on: December 27, 2005 - 12:01:21 PM »
I have a carter avs all rebuilt off a 68-69 383 cali car. I belive its #s are 4401-s I think its off a charger would have to look up the #s.
anyway if you need it im in sacramento.
1938 packard 120
1948 lincoln convertible coupe(1 of 16)
69 charger
70 challenger R/T 440 6 pac
71 challenger 340 R/T 4 speed
2-1961 nash metropolitans
forgive wifes 75 vette
2002 dakota 4.7
Offline Bondavi
« Reply #3 on: December 27, 2005 - 01:04:26 PM »
I think Richard (TropicalCats) will be able to help as he has a N95 car as well.
David
'70 Challenger R/T FC7 440-6 4spd N96 3.54 Dana - SOLD
Offline FY1 RT SE
« Reply #4 on: December 27, 2005 - 02:12:26 PM »
Carter 4734
Holley 4218
Holley carbs were pulled to a potential fire danger early in production and replaced with Carters.
Offline moparnut
    • My Photo's
« Reply #5 on: December 27, 2005 - 02:31:13 PM »
Thanks
Guy
Is you engine originally Blue or orange?I pulled the all original numbers motor out of my GC and i know its the original carb,If its Blue we would have the same engine and i could check for you since its sitting in my shop out of the car
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline rm23j8g
« Reply #6 on: December 27, 2005 - 03:05:26 PM »
My engine is orange....
Would the 383 4 barrel in a Grand Coupe be the same engine as a 383hp R/T or Cuda ...or the lower performance
383-4 found in non hp applications....like C bodies and such?  That, I'm not sure about.
Did your GC have air and N-95 ECS?
I didn't know that about the Holleys being replaced by Carters early in production.  I had thought that all non CA '70 383s had Holleys but.....
you learn something every day!
Thanks
Guy
Offline moparnut
    • My Photo's
« Reply #7 on: December 27, 2005 - 04:10:55 PM »
I am not sure if the carbs are different but the Blue engine was 330hp non A/c super commando and the Orange was A/c 335hp,Mine is non A/c,not sure if they both used tha same carb,Chryco would probably know
Offline moparnut
    • My Photo's
« Reply #8 on: December 27, 2005 - 04:13:56 PM »
Forgot to add,mine is the hp application BPNOE Vin,I dont know if the Non hp application would have the same carb
Offline rm23j8g
« Reply #9 on: December 27, 2005 - 04:29:48 PM »
Did either one of these cars have N-95....California ECS emission control?
Offline js27
  • MOPAR OR NO CAR
« Reply #10 on: December 27, 2005 - 05:16:45 PM »
My 70 R/T is also a Calif car. The original motor was gone but I check my broadcast sheet and it stamped 43 which stands for Holly 4369. When was your car built ?? Mine was built 11/20/69. My car is not an air car though so I don't know if that makes a difference.
JS27
« Last Edit: April 19, 2006 - 01:19:04 PM by Rev-It-Up »
1967 GTX
1970 Dodge Challenger R/T Conv.
Offline rm23j8g
« Reply #11 on: December 27, 2005 - 06:40:09 PM »
JS27
My car was built in, if memory serves without checking for sure...Nov 69 also.  Is yours automatic and was it built in LA also?
If it was, and you have a build sheet, then maybe there's a chance there might be one in this car too!
Guy
Offline js27
  • MOPAR OR NO CAR
« Reply #12 on: December 27, 2005 - 06:56:10 PM »
yes my car is an auto but it was a hamtramack built car with the N95 code. I have the gas tank with the 5 lines coming out of it with the vapor separator.
JS27
« Last Edit: December 27, 2005 - 06:57:55 PM by js27 »
1967 GTX
Offline moparnut
    • My Photo's
« Reply #13 on: December 27, 2005 - 07:11:17 PM »
Mine GC has N95,look at my webshots and i have the decode sheet posted there under GC
Offline js27
  • MOPAR OR NO CAR
« Reply #14 on: December 27, 2005 - 07:38:22 PM »
N95 is stamped on my fender tag..
JS27
1967 GTX
