Author Topic: 340 Valve Seals  (Read 1002 times)
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
340 Valve Seals
« on: December 27, 2005 - 11:09:24 AM »
Looks like I have to replace my Valve Seals in my 340.  I was wondering if there is any specific kind/brand I should look for???  :feedback:  :1zhelp:
Re: 340 Valve Seals
« Reply #1 on: December 27, 2005 - 11:11:44 AM »
there are rubber / nylon positive seals available , these are about the best to use  ,the factory just used an umbrellor type seal
  • Global Moderator
Re: 340 Valve Seals
« Reply #2 on: December 27, 2005 - 11:12:32 AM »
wow, that was a fast answer to my question!   Thanks Chryco!
Re: 340 Valve Seals
« Reply #3 on: December 27, 2005 - 11:13:44 AM »
you are welcome
I will send a set if you have  trouble getting them locally
  • Global Moderator
Re: 340 Valve Seals
« Reply #4 on: December 27, 2005 - 11:15:53 AM »
Sounds good to me, I will let you know if I can't find them.  Any particular brand I should be looking for?
Re: 340 Valve Seals
« Reply #5 on: December 28, 2005 - 12:11:16 AM »
My machinist gets them so I am not sure what he uses , probably Speed Pro / Federal Mogul
