need help !!! - how to remove corrugated cylinder ????
Author Topic: need help !!! - how to remove corrugated cylinder ????  (Read 1122 times)
Offline bs549
« on: December 30, 2005 - 10:22:03 AM »
...from the steering column on my 74 Cuda?  I've removed the nut, but the cylinder is pressed onto the splined steering wheel shaft.
Offline Cannibal94
Re: need help !!! - how to remove corrugated cylinder ????
« Reply #1 on: December 30, 2005 - 10:23:37 AM »
You need to use a steering wheel puller.  Just like a pully puller.
Offline hotrod98
    • Maniac Musclecars
« Reply #2 on: December 30, 2005 - 10:37:25 AM »
You will need one of those small steering wheel removers that you find at auto parts stores. It will need to be small enough to fit down in the can. Sometimes you have to grind the ends of the puller to fit.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: December 30, 2005 - 10:37:52 AM »
Yes that is correct!!  Need a puller to get that off!   :cheers:
« Reply #4 on: December 30, 2005 - 12:43:55 PM »
you can use a normal puller too If you use 6" bolts & a longer center bolt in the puller
Offline bs549
« Reply #5 on: December 30, 2005 - 04:03:26 PM »
Thanks a bunch!   Went down to AutoZone and borrowed a wheel puller. :working:
