Author Topic: Frame ties  (Read 10264 times)
Offline 6PKRTSE
Frame ties
« on: June 05, 2002 - 02:20:47 PM »
I'm going for the sleeper look in my restifcation.I just finished tieing the uni-bodies together,but I've done it differently than normal.I cut my rocker panels off,welded in 2"x3" tubing to the trans cross member at the front and at the back I tied into the frame rail from the side the near the spring perch location,once the boxed in spring perch plates & rocker panels were reinstalled you can't even tell that it is tied together.Has anyone else tried this?I'm hoping it is just as strong as going thru the floor pans.
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, 528 Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL.
1970 Road Runner 383 4 BBL
1996 2500 RAM 488 V-10 4X4
2012 Challenger R/T Classic
Offline BadHemi
Re: Frame ties
« Reply #1 on: June 05, 2002 - 03:00:55 PM »
Have any pictures, before, during, after?  That would be cool to see? ;D
Offline 6PKRTSE
Re: Frame ties
« Reply #2 on: June 06, 2002 - 06:00:55 AM »
Yes,I took alot a pictures,it definately came out nice,unfortunately I do not have a scanner here at work.Believe it or not I don't have a PC at home yet.
Offline dr_dodge
  • mopar or no car
Re: Frame ties
« Reply #3 on: June 06, 2002 - 03:46:32 PM »
I'd like to see the pics too
same stuff I am doing right now
dr
Offline BIG MIKE
Re: Frame ties
« Reply #4 on: June 06, 2002 - 09:28:19 PM »
i wonder if your boss will notice a scanner under your shirt ;D
Offline 6PKRTSE
Re: Frame ties
« Reply #5 on: June 07, 2002 - 07:14:15 AM »
Now that I have the frame connectors done.After I drop the monster elephant in,should I cage it or not?I was thinking of going with a 12 point.I have 6 tracks within a 3 hour drive that I can go to,since I will probably getting kicked off at each one,until I do cage it.I really don't want to because its going to be a real sleeper.But I don't want to set at home while my Chevy,Ford,Pontiac & Oldsmobile buddies are out ripping up the track.Plus we all have a major waiver on the line here,but I'm going to kick all of the A$$e$.
