Author Topic: engine wire harness  (Read 1048 times)
Offline justin16440
engine wire harness
« on: December 31, 2005 - 07:25:23 PM »
When I took my motor out the other day I notice my engine wire harness is pretty bad .  When I went to the yeasone site I got little confused on whick one I should get. I have a 74 cuda originally with a 318. now I have 440in its place. Should i get 74 ebody318  harness that is $200or I can use 70 or 71 ebody harness whick is alot cheaper. or is there anybody else that sells harnesses; thanks
Re: engine wire harness
« Reply #1 on: December 31, 2005 - 09:57:42 PM »
contact Evans wiring  @  http://evanswiring.tripod.com/
 they will build you a correct harness for you 74 Cuda with a 440 & I bet it wll cost less as well
Offline justin16440
« Reply #2 on: January 01, 2006 - 07:59:35 AM »
thanks
Offline Winston
« Reply #3 on: January 09, 2006 - 10:20:43 AM »
on this topic, does anyone have any pictures of their cars showing the routing of the engine and front headlight wiring harnesses?  i sold my other cars a little too quick and have no idea how to run the wires now.
btw, i got my harnesses from evans, and they look super.  i'm looking forward to seeing how they work.  thanks!
winston
« Reply #4 on: January 10, 2006 - 12:01:03 AM »
the headlight harness runs behind the battry along the inner fender on the left side & goes through the hole infront of the battery & is held in place with clips on the top of the rad wall
 the engine harness crosses the firewall behind the engine & is held in clips on the firewall & goes up the right valve cover & is held in clips on the cover & plugs into the water temp & alt at the front & goes out to the horns & washer tank on the right inner fender
