Author Topic: Reskining the roof...HELP  (Read 2244 times)
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Reskining the roof...HELP
« Reply #15 on: January 08, 2006 - 04:52:02 AM »
Some flex is normal but your roof may be "oil canning" from being stretched due to dents or from the sandblasting which is why I don`t recommend blasting large areas.I good body man can shrink the area back up by heating a small spot and using a hammer and dolly to push metal together thereby tightening the panel,not a big deal.I would first weld it on the car and reattach it to the structure and then recheck it for any bad spots.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 2000gt
« Reply #16 on: January 08, 2006 - 11:33:29 AM »
Ok then, so it is something that can be repaired once it is on the car.  I didn't want to do all the work then realize I couldn't use it.  It actually tightened up a bit during the blasting process.
