Author Topic: SE domelight expertise  (Read 2240 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« on: January 02, 2006 - 03:18:02 PM »
Just pulled my dome light down from the overhead console. When I got the car the little metal cover around the light switch was missing. I found a light on ebay to get the metal cover. Wish it had been in better shape!
Questions:
Picture 1. When I pulled the light there is an unused grey wire with a connector up in the console. What's it for? All three console lights work.
Picture 2. Back cover of new light on right has a plastic cover. My existing light has a metal cover.
              Which is correct for 70 Challenger ?
« Last Edit: January 03, 2006 - 01:04:00 AM by chevyconvert »
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline sccarts1
Re: SE domelight expertise
« Reply #1 on: January 03, 2006 - 09:41:55 PM »
its the ground lead for the seatbelt indicator light
  • HvacMan
« Reply #2 on: January 03, 2006 - 10:04:06 PM »
Thanks for the feedback. Funny thing is, that light works now... Where would the grey wire be grounded too normally?
Anything on which cover is correct? I'm assuming mine. Wonder what the other one came out of. Same p.#'s on back... :dunno:
Eric
Bay Area California
Offline sccarts1
« Reply #3 on: January 06, 2006 - 10:59:03 PM »
SEE IF YOU CAN DISCERN ANY PRODUCTION DATE. THAT/S YOUR BEST BET. sorryfor caps
Offline miketyler
    • www.miketyler.net
« Reply #4 on: January 14, 2006 - 05:03:32 PM »
Look closely at the topside of your dome light assembly. There is a male terminal that I believe that wire goes to.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
  • HvacMan
« Reply #5 on: January 16, 2006 - 01:33:34 PM »
Thanks I'll have a look. Since the light works without it, do you know it's purpose?
Eric
Bay Area California
Offline miketyler
    • www.miketyler.net
« Reply #6 on: January 16, 2006 - 08:11:15 PM »
cant say that I do but you can clearly make it out in the large side-by-side shots you posted
72' Cuda restomod
70 Mustang Mach 1
  • HvacMan
« Reply #7 on: February 08, 2006 - 08:47:46 PM »
actually, there isn't a male plug. It just looked like one in the pic.
Eric
Bay Area California
Offline Killer_Mopar
« Reply #8 on: February 08, 2006 - 08:56:06 PM »
That ground plugs into the bezel. I remember having a hell of a time trying to get it off when I took my light off. I will search for my light tommorow and take a picture of where it was connected.
  • HvacMan
« Reply #9 on: February 08, 2006 - 10:41:32 PM »
Oh I see the male plug now! Thanks Mike. Definitly a ground then.
Thanks for the help guys.
Time for me to rethink getting glasses.
Eric
Bay Area California
  • HvacMan
« Reply #10 on: February 08, 2006 - 11:14:27 PM »
killer, I have a different question for you...
how do you keep the little decorative metal cover around the switch on? It has 4 little tabs.
it has to be removeable to change the bulb so you don't have to remove the housing.
 :dunno:
Eric
Bay Area California
  • HvacMan
« Reply #11 on: February 22, 2006 - 08:55:52 PM »
 :feedback:
Eric
Bay Area California
Offline miketyler
    • www.miketyler.net
« Reply #12 on: February 23, 2006 - 05:01:13 AM »
I thought you had to drop the housing to change the bulb?
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #13 on: February 26, 2006 - 07:42:42 PM »
you definitely have to drop the assembly to change the bulb. The brushed stainless cover is fixed and not removable.
On another note; how is the domelight in an overhead console supposed to behave? I hooked mine up today and its acting wacky.  I assume the light should come on when the doors open and then also can be manually controlled by the switch on the light. Should it also be controlled by the dash dimmer switch?
Right now the light comes on with the door opening ok, but when operatedd manually, the light comes on when the switch is in the off position and the light is shileded from the the main lens.
After all of the wiring hurdles, I thought the dome light should be plug and play.  :banghead:
72' Cuda restomod
70 Mustang Mach 1
  • HvacMan
« Reply #14 on: February 26, 2006 - 09:10:38 PM »
Mike.. First of all, based on my car the dash switch is not involved at all.
The light comes on when the door opens.
The sliding manual switch on the dome light from what I can tell (and I'm still playing with mine) is kind of weird how it works. It seems like it relies on the metal rotating shield part of the switch to make contact with the surronding metal frame to complete the circuit and turn on the light when its rotated all the way "on". Without the decorative brushed cover in place, I can short the rotating metal shield part to the metal surround with a screwdriver and the light comes on..
I hope this helps in some small way.
Eric
Bay Area California
