Author Topic: 16"inch on "295"tires  (Read 1176 times)
Offline 73 challenger 440
« on: January 03, 2006 - 12:21:21 AM »
I have a 73 challenger, and i would like to put 16" inch Hopster wheels fited with 295 tires. As it is my suspecnig brand new and the body sit's above the wheels with a few inches to spare.What size backspaceing will i need for the rear wheel in oder form them not to stick out from the fender lip.If any one has ,simular  set up that im asking. please post picture n the back spacing. and will a 295 inch tire fit on a 9 inch wheel
Offline 73cuda426
Re: 16"inch on "295"tires
« Reply #1 on: January 28, 2006 - 10:53:28 AM »
I have 285/40/18's in back on 17x9 (5 inch back spacing)
I think 295 may be too wide w/ out spring relocation.
« Last Edit: January 28, 2006 - 11:14:23 AM by 73cuda426 »
Offline jvike
  • Pro-Touring Cuda
« Reply #2 on: January 29, 2006 - 07:12:46 AM »
You got 18"s on a 17x9?  :lol:
:useless:
Hehe, just messin' with ya  :thumbsup:
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
« Reply #3 on: February 04, 2006 - 09:18:40 PM »
I had 295/50-15's on mine.  In theory, they can fit but back spacing is critical.  Mounted on 8" rims, my tires measured 11-5/8" wide from sidewall to sidewall.  My fenderwell measures 5 1/2" from fender lip to brake drum and 6 1/2" from drum to spring, giving total clear of 12" min. I got the back spacing wrong and it ended up rubbing my fender lip.
A wider rim with a lower profile might give a little more clearance by reducing the sidewall bulge, but it probably won't be much.  I'd recommend going to 275's.  Much better clearances and you'll loose less than 1" in tread width.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
