Author Topic: Going to the blaster today  (Read 1976 times)
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: Going to the blaster today
« Reply #15 on: January 14, 2006 - 11:50:06 AM »
Did you sandblast or sodablast?  looks like sand.
I have had cars soda blasted and they come out great! It doesn not generate any heat so as to warp panels and doesn't take away any metal.
Dipping looks very interesting though as well.
2013 Tige' RZR 343hp
Offline RusTy/SE
  • Just havin' fun
« Reply #16 on: January 14, 2006 - 02:13:12 PM »
  Steve, ive got a question. It seems at least one quarter was removed before being blasted. Now i've never come close to doing bodywork (so far) but it seems to make sense that if a quarter will get replaced anyway, that it should be removed before being blasted so that a little less rust has a chance to ever pop up again. Am i thinking along the right lines?
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline Steve
  • I Love Welding!
« Reply #17 on: January 14, 2006 - 03:09:08 PM »
Rod at Blast Off using plastic media for large panels that might warp and uses aluminum oxide for sturdy areas, especially those with rust. I didn't end up with any warpage that I can tell. Of course, I didn't have much in the way of big surfaces and the roof already had an oil can spot.
My logic behind cutting the quarters off before blasting was that 1) I knew they were trash 2) having them off allowed Rod to blast the wheel well and other parts that would be accessible 3) less media would be trapped in the car 4) I can easily prime the clean metal all over prior to welding on the quarters. Worked out well.
Note that I had already replaced the floor and trunk pans. The aluminum oxide cleaned them up nicely and I just have to fill in some pinholes in my welds, dress the underside, and I can prime.
The blasting uncovered a nasty roof. Lots of pits and even a few pinholes. That oil can spot is going to require some shrinking to fix. BUT, there was this totally rotted out Challenger sitting down at the shop for Rod to blast. I'll take pics when I go down to pick up my other parts.
Offline RusTy/SE
  • Just havin' fun
« Reply #18 on: January 15, 2006 - 09:50:35 AM »
I follow you...few, if any, hidden areas to worry about when replacing pans so it makes sense to replace those before blasting in order to gain the cleanest possible surfaces for eventual paint and reassembly  :thinkerg:  :thumbsup:
Russ
2001 Durango     1B4HS
Offline Steve
  • I Love Welding!
« Reply #19 on: January 17, 2006 - 06:45:54 AM »
OK guys...check this out...not too bad.
« Last Edit: January 17, 2006 - 06:53:30 AM by Rev-It-Up »
