Author Topic: Hard to read.  (Read 1475 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Hard to read.
« on: January 06, 2006 - 02:43:49 PM »
Well I'm about a week or 2 away from sending the Chally out to body and paint. It should have happened a month ago but it's just bee to cold to work for long on stripping her down.
I have tried to come up with ways to save what I think is my build sheet which was glued to the floor under my carpet but I have run out of ideas so when the car gets stripped of it plum Crazy color whats left of the build sheet will be lost forever. Before it goes I just wonder if someone could look at  it at help to decifer. I'm just not sure what I'm looking at so any help would be great.
I have posted the picture larger to help bring out some details.
Thanks
« Last Edit: January 30, 2006 - 12:33:18 PM by Rev-It-Up »
SOLD
Offline hemi71
Re: Hard to read.
« Reply #1 on: January 06, 2006 - 02:54:52 PM »
Thats the top right side of a build sheet....if you want, send me a file of it, and I'll print it out and compare it to a blank i have and try and get what info i can out of it for you.  Sounds like a good "Challenge" to me!     LOL
Re: Hard to read.
« Reply #2 on: January 06, 2006 - 03:04:07 PM »
 :rofl:
Thanks Hemi
You got mail
SOLD
Offline 1970grancoupe
Re: Hard to read.
« Reply #3 on: January 06, 2006 - 03:28:58 PM »
So sad--you might find another sheet at the drivers backrest behind the plastic panel, attached to the top of the glove box, above the headliner, maybe under the seat springs. As I understand, they could put them almost anywhere. Also I've been told that they can't be re-produced.  Lots of luck.   P.S  Do you have the fender tag. Located on top of the drivers side inner fender?  That will give you a lot of info on your car.
Re: Hard to read.
« Reply #4 on: January 06, 2006 - 03:53:35 PM »
I have the car almost totally stripped and no other build sheet. I have not heard about them being reproduce. Do you have any other info on that?
I do have the fender tag along with the strip of metal found under the fender tag that was used to show completion at various stages in the line.
« Last Edit: January 30, 2006 - 12:34:35 PM by Rev-It-Up »
SOLD
HERE YOU GO
« Reply #5 on: January 07, 2006 - 03:12:02 AM »
Decoding of Fender Tag: Botttom to Top, Left to Right
Code Description
E63 383-4 Barrel
D32 H-D A-727 TorqueFlite Trans / Some Years A-998
JS23 J = Dodge Challenger
S = Special
23 = 2 Door Hardtop
N0E N = 383 330HP OR 335HP 1-4BBL 8 CYL
0 = 1970
E = Los Angeles, CA, USA
127979 Sequence Number '127979'
FC7 Paint Code: Plum Crazy Purple / In-Violet Irid
HRX9 Trim Grade/Style/Color
H = High
R = Vinyl and Leather Bucket Seats
X9 = Black
000 Upper Door Frame: Full Door Panel
106 Date Built: 1 / 06 / 1970
040693 Order Number: 040693
V1W Roof Type OR Color:  Full Vinyl Top - White
A62 Rallye Instrument Cluster
B51 Power Assisted Brakes
C16 Console w/ Buckets
C55 Bucket Seats
J25 3 Speed Variable Wipers
N21 Air Pump
N41 Duel Exhaust w/o Tips
N42 Chrome Duel Exhaust Tips
N85 Tachometer
N95 Nox Exhaust Emission Control
R35 AM / FM Multiplex Sterio
V1W Full Vinyl Top - White
V6W White Longitude Sports Stripe
Y14 Sold Car 69-71
END End of Codes
 :thumbsup: got any other pics of car--like to see work in progress. Buildsheets are a one time deal. :faint: As for the other small tag. Save it! I think it was additional options.
« Last Edit: January 07, 2006 - 03:25:03 AM by 1970grancoupe »
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Hard to read.
« Reply #6 on: January 07, 2006 - 03:33:16 AM »
Wow, tough situation!  If that gets stripped and painted over it's like part of the history of the car is gonzo.  That would put me in a bind.
Too bad there isn't a way you could preserve that part of the car when it's stripped and put a coat of clear over it to preserve it so at least you can still see it.  Just my wierd idea.  Hope you can figure out the codes!
A really stupid idea but I'll throw it out anyhow:  Do I dare suggest if it's a small portion of metal that we're talking about and you REALLY want to save it and since you're sending the car out anyway to have the body work done on it, what about cutting out that small area of floorboard? :22yikes:  Sounds stupid but if you really want to save that bit of history of the car and it's important to you to keep what's left of the build sheet.....
I can hear it now already:  :swear:
Offline hemi71
Re: Hard to read.
« Reply #7 on: January 07, 2006 - 08:50:05 AM »
You have a pic of the sheet already, just save it on a CD. Also, take some standard 35MM shots of it. Dont cut the floor pan up for it! The small additional tag is a line inspectors stamp tag...see the small lettered punches on it...it was punched by an inspector after he inspected the car at places along the assembly line.
Re: Hard to read.
« Reply #8 on: January 07, 2006 - 10:03:26 AM »
Thanks for running the fender tag 1970 I had done that a while ago the only difference I see is  the N21 It is actually M21 = drip rail molding. Sometime those are hard to see unless you have it right in front of you.
Super Blue
I don't think I could go ahead and cut out good metal.My floors are in such good shape and the only metal i need to replace is in the trunk although it would be one way to preserve it. I am considering clear coating it since its not something you will ever see but the darn thing is so brittle a breeze just knocks it apart.
« Last Edit: January 30, 2006 - 12:35:59 PM by Rev-It-Up »
SOLD
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: Hard to read.
« Reply #9 on: January 08, 2006 - 08:17:46 AM »
Your floors are really too nice to even think about cutting up.  What a shae, I feel so bad about this buildsheet situation!   :pullinghair:
Re: Hard to read.
« Reply #10 on: January 08, 2006 - 10:21:31 PM »
Ya, your floors are pretty nice.  Just a goofy idea.  Desperate situations require deperate ideas!  :D
The photo idea might be the most reasonable way to go as hemi71 suggested.  I'm out of ideas.
Offline Carlwalski
Re: Hard to read.
« Reply #11 on: January 08, 2006 - 10:27:40 PM »
Yip, you'd be silly to cut it. You can drive a car, not a build sheet.  :thumbsup:
You have photos so documenting it isn't a problem.
Try using a hair dryer set on half way for a good 30 minutes and see if that helps.  :dunno:
NZ440R/T
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
Re: Hard to read.
« Reply #12 on: January 08, 2006 - 10:40:13 PM »
Clear coat it in place :2cents: That way it's there, and it won't show anyways. :smokin:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
