Author Topic: New meats ordered from Summit...  (Read 2251 times)
Offline cudacharlie
  • 70 Cuda convert, 70 Charger R/T
« on: January 07, 2006 - 03:53:45 PM »
Well, I read every single post and thread relating to tire sizes on E-body cars (whew), and to avoid being a guineau pig with 10-inch rims, a welding torch and spring relocation kit, I've decided on this combo for my 1970 Cuda convertible:
15x8 rallyes with BFG radial T/A 275/60-15's on the back
15x7 rallyes with BFG radial T/A 245/60-15's on the front
I ordered them from Summit Racing for $1079, mounted, balanced, delivered with trim rings, center caps, and lug nuts...
As soon as they come, pics will follow...
NZ440RT and Chryco thanks so much for all your posts, it helped a lot!
-- BTW:  My 2006 Magnum SRT8 will be arriving on Jan. 25th!  425hp!  (gulp) ---
« Last Edit: January 07, 2006 - 06:44:47 PM by cudacharlie »
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Re: New meats ordered from Summit...
« Reply #1 on: January 07, 2006 - 04:52:44 PM »
Yep, without modifications, that's as big as you want to go. I can't wait for the pictures!!!  :popcorn:
Oldschool
« Reply #2 on: January 07, 2006 - 04:56:52 PM »
That ought to fill up those wheelwells nicely!   :drool:  I can't wait to see the pics.   :cooldancing:  ..........Oldschool
Offline Carlwalski
« Reply #3 on: January 07, 2006 - 06:51:47 PM »
Good choice!  :bananasmi Same as what Lucy wears and her stance is great (IMO).  :thumbsup:
No worries, about the help, just don't forget to post us eye candy!  :naughty:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline cudacharlie
« Reply #4 on: January 07, 2006 - 07:34:48 PM »
Oi!
One thing I forgot is that I have wheel well moldings... for a second there I thought I might have to notch them, but I see that you have them too, NZ....  so no worries, then, eh?
And, I forgot to tell them to mount the tires with white letters OUT... you don't think there's any chance they'd mount BFG white letter T/A's with the letters IN, do you?  Maybe I better call...
Oh and wait till you see the Magnum SRT8... it looks wikkid in black!
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Offline 71340RT
« Reply #5 on: January 07, 2006 - 08:39:53 PM »
That may end up being the tire size I put on my car. I put new leaf springs on the rear end sits up so high now it really needs some 15 inch wheels and tires. Post pictures as soon as you can so I can see how it looks with them installed.
« Last Edit: January 07, 2006 - 09:08:57 PM by 4cruzin »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline cudacharlie
« Reply #6 on: January 08, 2006 - 12:44:10 AM »
Hey 71340RT what size are on there now?  Aren't those 15-inch rallye's?
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Offline Carlwalski
« Reply #7 on: January 08, 2006 - 01:30:14 AM »
Oi!
Nope, no worries with the moldings.  :thumbsup:
Offline 71340RT
« Reply #8 on: January 08, 2006 - 10:54:18 PM »
No I have the factory correct 14X6 rallye's on my Challenger now. It just has 225X70 BFG radials on it now.
Offline cudacharlie
« Reply #9 on: January 14, 2006 - 12:47:57 PM »
Okay, so the new baloneys came from Summit, quick as a wink.. Only problem is that my right front wheel is stuck on the hub!  Even with all the lugnuts loosened, that sucker is like bonded to the hub or something.  Before I take a sledgehammer to it, any slick suggestions?  I don't want to spray WD or something anywhere I'm not supposed to, but how in heck can I get this sucker off?  Is there a prying technique that I don't know about, or a preferred place to whack on the sucker to loosen it?  I even lowered the car back onto the wheels a bit, hoping that would break the seal, but no dice.
Plumbers torch?
Pry Bar?
Pep Boys?
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Offline 73 challenger 440
« Reply #10 on: January 17, 2006 - 04:35:27 PM »
I would spray some ruster blaster around the part thats stuck (between wheel and  rotor) and loosen all the bolts just enought that there is a hair of slack, cut the wheel one way and go back and forth a several inches to see if it breaks it loose, I did this once when I had a problem.. it worked
Offline cudacharlie
« Reply #11 on: January 17, 2006 - 04:40:37 PM »
GOT 'EM!  The top part of a sixton jack stand makes a good sledge!  Thanks guys... pics on the way...
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Offline Carlwalski
« Reply #12 on: January 17, 2006 - 05:08:57 PM »
Offline onebadhemi
« Reply #13 on: January 17, 2006 - 07:16:19 PM »
 :popcorn: :bigshades:
1970 R/T Challenger
1971 Pro street"HEMI" Challenger
2003 V-10 Ram 2500 Q/C
2006 Charger R/T
Offline cudacharlie
« Reply #14 on: January 19, 2006 - 06:15:07 PM »
Yeah, baby..... got 'em on there....  275-60r15 (rear) and 245-60r15 (front) on 15x8 and 15x7 Wheel Vintiques Rallyes with polished trim rings and 70 center caps....
Then, we have almost an inch on the inside and even more on the outside....  295's?  305's?  hmmmm....  Thanks guys for your help!
 :picture:
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
