Author Topic: swapping trannys  (Read 2525 times)
Offline Mr.T
  • I'm a llama!
    • MazdaTalk.com
swapping trannys
« on: January 06, 2003 - 01:06:42 PM »
how hard would it be to find a manual tranny for a 72 340 cuda? does it make any difference on these cars between atx and mtx trannys? thanks
T
1996 Mazda Mx-6
(hoping for:)1972 340 'Cuda
Offline gizzard-1
Re:swapping trannys
« Reply #1 on: January 07, 2003 - 01:44:10 AM »
Well swapping from an auto can be done but you need all the parts like linkages, z bar and such. The tranny crossmember should be the same.  You also need to be sure your crank is drilled for the pilot bushing. That year e body used a 23 spline tranny.  You should be able to salvage one from any e or b body.  A bodies were shorter.  Try darklair.com this guy swapped a 727 to a manual in great detail in a charger I believe.
2nd place is for the 1st place loser!
02 Ram Big and Red
73 'Cuda Yellow
70 Charger 500 Black
Re:swapping trannys
« Reply #2 on: January 07, 2003 - 03:23:51 AM »
 I have some trannies available ,you need to cut the floor for shifter clearance & weld in a floor hump & locate all the linkage a pedals ,Brewers carries a lot of the parts  ;)
