Author Topic: 1.88 vs 2.02 Valves  (Read 3707 times)
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
1.88 vs 2.02 Valves
« on: January 08, 2006 - 08:03:46 AM »
Well, yesterday I got my heads off and will be sending them in to be redone including a 3 angle valve job.  My J heads have the small valves.  I was wondering if anyone had any info on changing to the 2.02 valves.  What kind of price difference do you think I will see at the machine shop, and do you think the results will be worth the money?
Also, what do you think about this cam?  280*/474" for my 340?
Thanks guys!   :jumping:  :jumping:  :jumping:
Offline CudaNut
  • She's so fine ain't no tellin where the money went
    • CUDANUT.COM
Re: 1.88 vs 2.02 Valves
« Reply #1 on: January 08, 2006 - 08:33:04 AM »
A lot depends on the rest of the combo...compression, intake, headers, gearing. The large valves hurt torque a little on the low end but the big valves breathe better up top especially with a little bowl work on the heads. A few years back I ran a 340 in a 72 Cuda with the exact same cam you mention, it had  10-1 pistons, 1.88 "J" heads, dual plane Edeldrock with 700 DP, headers and 3.91 gearing. I switched to the 2.02 heads and it picked up 2/10 in the 1/4 but my 60ft and 1/8 times were slightly slower.
"If I had my life to live over again, I'd be a plumber."
  Albert Einstein
  • Global Moderator
« Reply #2 on: January 08, 2006 - 08:40:02 AM »
I guess I should have mentioned that I will be using a 6 pak set up, I have 4:10s and TTI Headers.  Not sure about the compression.
« Reply #3 on: January 08, 2006 - 10:27:44 AM »
can you gat a set of the truck 308 castings locally
 They are worth 40 hp , seriously , I have witnessed it twice on the dyno , far better heads
 the 474 cam works well , too bad the 471 isn`t still available , too bad the .474 isn`t available in the 114 cl version
  • Global Moderator
« Reply #4 on: January 08, 2006 - 11:58:50 AM »
Thanks Chryco, I am going to see if I an find a set of the 308 castings.  I forgot all about those.  Do you think it is going to be worth my while to go with the 2.02s?  Will I notice a big difference with my everyday driving on the street?
Oldschool
« Reply #5 on: January 08, 2006 - 02:08:54 PM »
April,  it sounds like you are very interested in getting the most performance potential from your small block.  I base this on what you already have done.  Cam, 6-pack, Tti headers, & 4.10 gears.  If you want to really let her breath, get the 308's.  Will you feel the difference by "seat of the pants?"  Yes, but the difference will be above 2500 rpm's. Anytime you are wanting performance, you must let the engine breath. That's what these heads/valves will do. If you can't find the 308's, it would probably still be worth the effort to get the 2.02's installed along with appropriate bowl work. It's all about the breathing. Just my   :2cents:    :cooldancing:  .......Oldschool
Offline moparnut
    • My Photo's
« Reply #6 on: January 08, 2006 - 02:10:23 PM »
Chryco What year trucks were these on?thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
« Reply #7 on: January 08, 2006 - 02:12:13 PM »
I appreciate what she wants to do, but the one unknown is her torque converter. All this new found power and all, I wonder if it can handle it?  :dunno:
« Reply #8 on: January 08, 2006 - 11:07:06 PM »
87-92 360 trucks , yes April I would use the 2.02 in you application Assuming you wil be bowl porting the heads
 if she cavs the converter I guess it will be replaced next
Offline Follicly Challenged
« Reply #9 on: January 15, 2006 - 04:25:52 PM »
Ever thought about using some "cut down" 2.02 valves ?
We found great success, as in "quicker off the turns" in CASCAR by cutting down some 2.02's to 1.97", gave back valve "margin" on some wore out pieces. At the time, we were just looking for "Anything to get back running", but stumbled upon some huge torque increases. Yes, we were using 308 heads back then. This assumes the stems aren't wore out too of course.
