Author Topic: how to make a clone T/A  (Read 3622 times)
Alaskan_TA
Re: how to make a clone T/A
« Reply #15 on: January 08, 2006 - 07:38:47 PM »
Hey Carl,
Well, your R/T was built at the LA plant (all T/As were built at Hamtramck) , and your R/T was built several months before the T/As hit production. So, I would have to guess that the antenna was moved at some point? Was there any evidence that either the passenger side fender or quarter panel or both had been replaced? Is the car coded for a radio or is it radio delete?
T/Ake care,
Barry
Offline Carlwalski
« Reply #16 on: January 08, 2006 - 07:44:28 PM »
Hey Carl,
T/Ake care,
Barry
Thanks Barry, the car is coded: R35 = 10 watt AM/FM Radio.
The car is all original, original panels and fenders, nothing was moved or changed as far as I could see.
Kind of weird. But I prefer it at the back so it leaves the hood area smooth and clean.
Cheers,
Carl
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline SlimeChallenger440
« Reply #17 on: January 08, 2006 - 08:03:14 PM »
Thanks alot for all the information. That was a lot of help.
Alaskan_TA
« Reply #18 on: January 08, 2006 - 08:23:28 PM »
Hey Carl,
Here is an original one from a T/A for comparisons sake.
T/Ake care,
Barry
« Reply #19 on: January 08, 2006 - 10:57:48 PM »
1 other thing not mentioned is the welded Torque plates around the front leaf spring boss on T/A cars
 I cannot get rid of the large dead spots Redline should be ablt to though
Alaskan_TA
« Reply #20 on: January 08, 2006 - 11:10:29 PM »
Hey CP,
I mentioned the front and rear toque boxes on page 1.  :cheers:
I may have missed other details though?  :dunno:
T/Ake care,
Barry
Offline Carlwalski
« Reply #21 on: January 08, 2006 - 11:27:44 PM »
Hey Carl,
T/Ake care,
Barry
Thanks Barry, seems as though someone put my aerial in. Although, there isn't any evidence of it.  ???
The aerial in the photos of my Challenger is a new one, I have the original in storage.
Could they have possibly put it in the wrong location?  :dunno:
The fenders at the front matched the age of the rest of the car.
Cheers,
Carl
« Reply #22 on: January 08, 2006 - 11:39:28 PM »
sorry Barry I missed it reading through the posts
Alaskan_TA
« Reply #23 on: January 09, 2006 - 12:00:26 AM »
Hey Carl,
 There would have been no reason I can think of for it to have happened at LA? Maybe it was done by the same person that did the custom spoiler?
CP, no big deal, I have done the same thing before, I even misspelled torque, a toque goes on your head I believe? If I never made mistakes no one would know it was really me.  :banghead:
T/Ake care guys,
Barry
Offline lemurfart
« Reply #24 on: January 09, 2006 - 03:34:47 PM »
how hard is it to put a T/A fin on?
2008 Ducati 1098 - Flat Black :)
1972 Dodge Challenger 340-4-4speed pistol
Alaskan_TA
« Reply #25 on: January 09, 2006 - 08:40:59 PM »
It is pretty easy. First Place Auto Products sells them with the correct attaching hardware, visit www.fpap.com for more info.
Here is a diagram of where to drill the holes. If your decklid does not have the correct holes in the underskin, you will have to modify it. FPAP sells marking stencils for this also.
It is not shown on the diagram, but the 4 outer holes 1/4" inch, and the four in the center ar 3/8" inch.
T/Ake care,
Barry
Offline Richie61
  • Pedal to the metal!
« Reply #26 on: January 09, 2006 - 10:50:36 PM »
I thought the rear leaf springs where de-arched to gain height in the rear for the exhaust?
Plus I thought the fenders had a larger wheel opening?
« Reply #27 on: January 10, 2006 - 12:09:17 AM »
the front fender had the Hemi fender with rolled lip the rear springs were standard as far as I know but used the taller rear tire to lift the car
Offline pink panther
« Reply #28 on: January 12, 2006 - 07:53:48 AM »
Slime,
I tried to respond to your PM, but it said the e-mail address wasn't existing.
Here are a few.
