GomangoRT/SE s restoration progress on rotisserie
Author Topic: GomangoRT/SE s restoration progress on rotisserie  (Read 3174 times)
Offline gomangoRT/SE
« on: January 09, 2006 - 02:26:53 PM »
Thought I would post a few pics of the car in progress.    In some pics you will see the car originally gomango was at one time painted Red, black, and the last dimwit painted some areas limelight green in places to see if he would like it. Car went thru 3 owners with good intentions but never took the steps needed to complete the car.  I hope I am not the 4th.   Take a look at the firewall area.   Probably at one time since the car sit for so long (since 1997) leaves clogged the vent and rusted an area of the firewall,  an earlier owner tried to hide it with bondo,  I cut the area out in one pic shown, and cut out a replacement area from another firewall.    The area in front of the driver side rear wheel was the same.   I cut out the bondo and rusted area and purchased a replacement panel from the Paddock and you can see how I have rough fit it in.   I have welding still to do.   In the passenger rear qtr close to the drain plug there is a spot about 1 inch that needs a little work, though not bad.    Lucky me I have excellent floors, trunkpan and framerails,  this is cause the car spent 80% of its life in Vegas.    Lots of work still to do, but the body is stripped and doors are on cause I rebuilt the hinges and I wanted to check the clearances.  I have everything stripped including the both sides of the hood.   I will go back with self etching primer then primer over that before I paint. Still have some finishing out with scotchbrite or sandpaper.   I wont paint the outside of the car though, just dont have the skills or confidence needed for that.   I am thinking for the underneath side, outside, floors, trunkpans and firewall about 3 gallons of paint.  I dont wanna run short on paint and would rather have some left over in cause of flaws or future mishappenings ...god forbid.   Currently rebuilding a 69HP 440 for this originally 383 car.  Since its an RT/SE I have most of the cool options on the car.
When I get more done, I will post pics of the progress.   Thanks all.....
Re: GomangoRT/SE s restoration progress on rotisserie
« Reply #1 on: January 09, 2006 - 04:00:44 PM »
Thanks for the update pics.  :thumbsup:  Good luck with it.
Offline RUSTY Cuda
  • One big step foward!
« Reply #2 on: January 09, 2006 - 05:30:55 PM »
Looking Good, must be nice getting down to bare metal & actually having some! Car looks really solid! Rich.
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« Reply #3 on: January 09, 2006 - 06:36:59 PM »
Kevin
Looks great. Nice to see things moving forward.  :thumbsup:Keep the updates coming.
SOLD
daves70
« Reply #4 on: January 09, 2006 - 07:10:36 PM »
Looks great! Keep the updates coming! :thumbsup: :thumbsup: :thumbsup:
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #5 on: January 09, 2006 - 08:17:23 PM »
 :22yikes: :22yikes: Wow!! You've really done a lot of work!  It looks fantastic!  Do you have a timeframe for the painting?
« Reply #6 on: January 10, 2006 - 06:49:52 PM »
I am hoping to get the body painted in the spring, perhaps April or May.   Not sure how much paint I am really gonna need.    And I still have alot of primering and blocking to do.    I am hesitant to buy paint to paint the bottom of the car till I get a commitment on who is gonna paint the car.   I dont wanna paint with something he doesnt feel comfortable with.....brand wise.    Some like PPG, some like Dupont and some like Sikkens....hope I spelled that right......
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« Reply #7 on: January 12, 2006 - 01:16:21 PM »
Look like a real total restore, looking good. I will start restore mine SE soon(its all about money). Its gonna be great seeing the progress on it...
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline Carlwalski
« Reply #8 on: January 12, 2006 - 01:19:46 PM »
Thanks for the photos!!  :bananasmi She looks really solid.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #9 on: January 12, 2006 - 06:09:23 PM »
Wow, I thought I replied to this post already!  Great jon GoMangoRT/SE!  Nothing like having a rotisserie!  Keep the pictures coming!
Offline 71340RT
« Reply #10 on: January 13, 2006 - 12:01:13 AM »
Great pictures and the Challenger does look like a solid project. I painted the bottom of my Cuda including trunk and passenger compartment with a gallon and half of single stage PPG. Some colors cover easier than others so it pays to make sure you have enough paint. I painted the door jams, engine compartment, and body with 2 gallons of base and have about 1/2 gallon of my original mix in case something stupid happens. The body has 3 coats of clear and I bought a gallon for the outside and it was just about gone after 3 heavy coats. Everything else was cleared with buying another 2 quarts of clear. You can imagine how much I have tied up in just the paint and clear not counting any primer.
« Last Edit: January 13, 2006 - 05:23:43 AM by Rev-It-Up »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline RusTy/SE
  • Just havin' fun
« Reply #11 on: January 14, 2006 - 01:59:09 PM »
 :cheers: :thumbsup:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
