Author Topic: scratches  (Read 906 times)
Offline justin16440
scratches
« on: January 09, 2006 - 05:57:15 PM »
I am in the process of painting my engine bay and I have a couple of ?`s   I used 50 grit sandpaper to get rid of some flaking paint and got a little excited and sanded alot of the engine bay with it. Will some of the scratches show up if I primer over it. Or do I have to sand the sratches away.
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: scratches
« Reply #1 on: January 09, 2006 - 07:01:34 PM »
Resand with 180 and the reprimer with a high build urothane primer, then 320 and wetsand with 400, and primer seal. If you are using laquer primer then 400 grit after 180 and recoat with laquer primer and you should be OK.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline JCWCuda
Re: scratches
« Reply #2 on: January 10, 2006 - 04:54:42 AM »
it may seem like a lotta work but it WILL be worth it :ylsuper:
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
Offline justin16440
Re: scratches
« Reply #3 on: January 10, 2006 - 07:44:50 AM »
AfterI wetsand the final coat of primer Do I put on my basecoat or do I scuff it up alittle witha green scotchbrite pad before the basecoat.
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: scratches
« Reply #4 on: January 10, 2006 - 07:50:45 PM »
After you are satisfied that all repairs are done, wet sand with 400 grit. pre wipe, tac and apply Primer sealer before basecoating. This will ensure a smooth surface. Primer sealer will flow into any light srates and fill them in and insure any contaminate from causing reaction with your top coat. This will be very beneficial with any metalic colors.
