Author Topic: Edelbrock high rise intake  (Read 783 times)
Offline Stacked440
« on: January 09, 2006 - 10:18:52 PM »
I have an Edelbrock high rise intake for my 440 but i also have a stock one, will the high rise fit under a power bulge hood without clearance issues?  Its going to have stock set up as far as carb and air cleaner goes.
-Kyle-
Re: Edelbrock high rise intake
« Reply #1 on: January 10, 2006 - 12:23:34 AM »
I guess it depends which intake you have , the air cleaner will usually hit unless you use a drop base
Offline gomangoRT/SE
« Reply #2 on: January 10, 2006 - 06:54:31 AM »
I have the same problem.   I have a Edelbrock RPM manifold that most recommend, however I am told my air cleaner wont clear the hood unless I use a drop base.   Then I wonder if I cut up my air cleaner will the drop base come into contact with the side of the carb cause I gonna run vacuum secondaries.    I read where you cut out the center of the stock cleaner and drop it an inch and half approx and weld in.    I am flustered as to keep this manifold or go with the Holley Street Dominator.   I dont like the idea of cutting up an original stock cleaner but may do so.
KTO
« Reply #3 on: January 10, 2006 - 07:42:52 AM »
I have a performer RPM intake and ran in to the same problem.
You might be able to buy a drop base air can from Edelbrock and use just the bottom and the stock top.
I had to mess with a combination of bases and lids until I got the fit right.
