Use a 75 deg. "Bowl Hawg" above the valve, in the bowl, after enlarging for the 2.02", or "mildly" port/blend the bowls.
If you pollish the Rod beams, re-harden with SOMETHING, even glass bead 'em. Still better than nothing. Takes many thermal cycles to re surface-harden, not that it's a big issue, lots run forever with "shiny" beams, just that if you're there, you might as well.
