I need to buy a brake at some point, too. I'm sure it'd help with some of the stuff I need to fab for the car (such as the piece that needs to connect the trunk floor to the tail panel).
Here's the update!!
OK, what you didn't see in the last picture was how much clearance there was between the trunk extension and the rear crossmember extension. Take a peek:
At the bottom there's almost an inch that needs to be closed up. That's where my state of the art metal-working tools come in (oops, the fire extinguisher is not part of the tools).
Here you can see how I carefully position the "tool" against the trunk extension.
Fitting the re-worked trunk extension.
Now it's time to get the gas tank braces put into place! I traced around the seams so I know where to drill the spot welds.
Spots drilled...
Now I've flipped the panel over and screwed the brace into place.
And voila! We have spot welds!
I think these came out pretty good! The heated area is about the size of a nickel.
