Author Topic: Rusty Roof Repair  (Read 1740 times)
Offline Tejas R/T
Rusty Roof Repair
« on: January 11, 2006 - 04:25:38 PM »
Does anyone have ideas on how to fix rusted roof panels?
My project car has rot around front and rear glass and some small holes a few inches forward of the rear window that someone has filled with bondo. I have a donor car but the the roof on that car has been used as a trampoline by someone and has some creases in it.
I,m affraid to do to much welding on it in fear of warping it.
Has anyone welded around the windows safely?
I'm thinking of repairing it with fiberglass on the inside and outside but I'm concernd about the longevity of a repair like that.
Ideas anyone?
« Last Edit: January 11, 2006 - 06:17:21 PM by 4cruzin »
Offline Stacked440
Re: Rusty Roof Repair
« Reply #1 on: January 11, 2006 - 08:13:36 PM »
I had the same issue as you, rusted right on the lip, making it incredibly hard to just make a simple patch.  I found a donor roof that had a few dings and pounded them out and then drilled out all the spot welds on both roofs and swapped them.  Works great but its a lot of work...its really the so called "Right" way to fix your roof to get the best resistance to rust.  Also before i put the "new" roof on i sprayed from Krylon semi-flat black "Rust-Tough" paint on the skeletal frame just to keep it from rusting. :thumbsup:
-Kyle-
Offline Bueller1
« Reply #2 on: January 12, 2006 - 06:25:03 PM »
I just patched mine with some 18 g. sheet metal.Weld a little at a time.I had a bunch of small areas to do.
Offline ArcticCuda
    • Pepe
« Reply #3 on: January 13, 2006 - 12:47:33 PM »
Hi. My roof is welded v e r y carefully...weld + air weld +air wled +air and seams are tinplated. No problems!
« Last Edit: January 13, 2006 - 12:49:22 PM by ArcticCuda »
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
