Author Topic: how do you guys achieve crisp off idle response?  (Read 2389 times)
Offline thetex
Re: how do you guys achieve crisp off idle response?
« Reply #15 on: January 31, 2006 - 01:29:55 PM »
The .015 gap is set at WOT to keep from  damaging the pump arm, that is what I meant.
Offline Mt.St.BigBlock
« Reply #16 on: January 31, 2006 - 03:08:48 PM »
HI,
  I've read a tech article that appeared in Popular Hotrodding in the November
2005 issue written by David Vizard. Seems to cover this problem and a possible
cure. Seems annular discharge boosters can make a big difference in making a
large carb "come to life" on the bottom end off idle situations. Booster Science
is the name of the story and I thought it was good reading! Whether it helps you
or not I don't know. Goodluck   Jeff
71 cuda 383 3spd manual gy9
