2 steps forward 1 step back
Author Topic: 2 steps forward 1 step back  (Read 1083 times)
Offline pandamarie
  • I love YaBB 1G - SP1!
« on: January 13, 2006 - 04:01:24 PM »
I got the carbs on my 6 pack challenger rebuilt and running good and found the timing offwhen I turned the bolt to loosen the dist(while engine was running) slipped and retaded it enough to shut the engine off, when I went to restart it the fuseable link went up in smoke, lucky for me thats all that went. after taking it apart it looks like it was corroded at tha 10 guage wire to the ign. switch. at least its an easy fix.
1938 packard 120
1948 lincoln convertible coupe(1 of 16)
69 charger
70 challenger R/T 440 6 pac
71 challenger 340 R/T 4 speed
2-1961 nash metropolitans
forgive wifes 75 vette
2002 dakota 4.7
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: 2 steps forward 1 step back
« Reply #1 on: January 13, 2006 - 04:17:15 PM »
A resto is full of backward steps!  Don't let it get to ya....just keep moving forward as much as possible so Mr. Murphy doesn't get a foothold.  It could have been worse!
Offline 71340RT
« Reply #2 on: January 13, 2006 - 11:26:16 PM »
I have run into many backward steps restoring both my Challenger RT and Cuda mostly by myself in a 2 car garage. You just have to take a step back yourself and look at whats going on and move to something else somtimes and then come back to what took the step backwards. This has worked for me many times.
« Last Edit: January 30, 2006 - 03:46:43 PM by Rev-It-Up »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #3 on: January 14, 2006 - 08:49:16 AM »
 :banghead: Know all about that "backsteping", the Charger and Chally were a piece of cake, but then again when I got them they were all in one piece as in assembled, ya know like...........complete! The 72 RR (clone) was a rolling shell, and it didn't have the dash in it (it was in a box) nor was the sterring column obviously in place. The rest of the "parts" ( what was actually there) were in bags, baggies, boxes, and just plain laying loose in the car. Now, talk about backstepping, hell at times I felt like I was moon walking, but I can't do that either. Just have patience, a helping wife (or girlfriend) who will put up with excessive cussin, and a steady supply of cold brews for that  :pullinghair: needed break. But she was running last October (after three years), took her for a couple short rides and put her in the "barn",..........smelled gas fumes, very strong? Guess what, the fuel line connector going into the middle carb was very much leaking even though the ferrell connector seemed significantly tight, here the connecting fitting is loose and even seems stripped, how could that have hapened? "Another step in that reverse direction", but hey, it's fun to work on them, it makes the neighbors beleive I know what I'm doing, I wonder?............... :roflsmiley:
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: January 14, 2006 - 12:03:15 PM »
Something must have shorted out to take out that fusible link. Make sure you check out all your circuits for a short.
2013 Tige' RZR 343hp
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #5 on: January 14, 2006 - 02:09:32 PM »
My fuseable link went up in smoke for  me on my Charger when I started her up. It was a short circuit in the steering colum. the plastic had worn of the mian power to the ignition. Everyting died on the car. I had no power at all. but thanks to the fuseable link noting else burned of, except the fuseable link of cause   :thumbsup:
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline pandamarie
« Reply #6 on: January 14, 2006 - 02:17:52 PM »
I found the cause of the fuseable link going up in smoke, it was just a loose and corroded connection where the fusebale link connects to the 10 guage wire to the ignition switch. replaced it with a 10 guage wire with a 15 amp blade fuse, tested for shorts and battery draw when off and have nothing. engine starts much eaiser than when I got it back.
Now I can start cleaning it.
1938 packard 120
69 charger
2002 dakota 4.7
Offline JS27N0B
« Reply #7 on: January 14, 2006 - 04:21:38 PM »
Be careful, only thing that will take out a fuse link is too much current, not a poor connection that won't flow current.
