Indy Hemi Combo
Author Topic: Indy Hemi Combo  (Read 12469 times)
Offline cudabuyer
Indy Hemi Combo
« on: January 13, 2006 - 02:15:29 PM »
Here is my engine build:
INDY Aluminum, std deck height Hemi water block
Eagle 4340/4.250 stroke, nitride hardened, non-twist forging, Cro-Moly crankshaft
RPM 4340/7.100 Cro-Moly, H-beam connecting rods
ROSS custom forged 2618 aluminum, quench dome pistons
Total Seal Gapless top moly ring set
Clevite 77 H-series rod main bearings
Fel-Pro gaskets
ARP fasteners
STAGE V aluminum street heads with mild porting and polishing
STAGE V roller rockers
Keith Black Racing Engines rocker stands
Keith Black Racing Engines hardened rocker shafts
Smith Bros custom pushrods
Comp Cams custom ground hydraulic roller retrofit camshaft
Comp Cams retrofit hydraulic roller lifters
Crane billet double roller, Torrington bearing, 3-bolt timing chain
Melling high volume oil pump
Milodon low profile road race oil pan
MSD pro-billet distributor and complete MSD ignition components
ATI harmonic balancer
McLeod billet steel flywheel
Stage V dual quad, single plane intake manifold
PC Carbs custom built Holleys
Moly coated rod and main bearings
Thermal barrier coated pistons and combustion chambers and valve faces
Billet Specialities Polished brackets and components
TTI ceramic coated headers
Fully dyno tuned - to be ~700+hp
STAY TUNED FOR ENGINE COMPLETION around Valentine's Day - shipping 3rd week and install 1st week of March
« Last Edit: January 15, 2006 - 11:55:04 AM by Chryco Psycho »
70 Dodge Challenger Convertible 6.1 Hemi
Offline cudabuyer
Re: 528 Hemi Combo
« Reply #1 on: January 14, 2006 - 06:22:40 PM »
Oldschool, I was looking at the Be Cool radiator with dual fans price from Summit was about $1400 - is that correct?  I will be upgrading to a new driveshaft - are you happy with the aluminum price is reasonable that I saw.  I was also interested in the strange 60 not sure about the gears tho and I would love to have a gear vendors overdrive but I am SOOOO way over budget.
Oldschool
Re: 528 Hemi Combo
« Reply #2 on: January 14, 2006 - 06:36:02 PM »
Cuda--the Be-Cool price looks in the ballpark.  It keeps my sled at 190* or cooler at all times.  If it was a REAL hot day, I would pour a little octane booster in it just to make sure.  But it never has gotten over 190*  I ran Strange equipment in my '65 990 Hemi SS car for 3 seasons and never even pulled the rear cover off after initial build-up.  It's strong stuff. But I also understand budgets......my wife is standing next to me, so I won't go there now...   :roflsmiley:    :cooldancing:   .............Oldschool
Offline cudabuyer
Re: 528 Hemi Combo
« Reply #3 on: January 15, 2006 - 04:56:18 AM »
Thanx for the info, engine install should take place in March - I am trying to finalize those crucial parts to purchase to have ready on install ie. radiator, drive shaft, rear end, motor mounts
I need your suggestion on the motor mounts and any other accessories for the engine swap from 340 to HEMI
Offline ChallengerGary
    • Challenger Gary
Re: 528 Hemi Combo
« Reply #4 on: January 15, 2006 - 06:58:26 AM »
Joel,  Sounds like quite an engine they're building fo you!  Any guesstimate on the HP/Torque that beast will put out?
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Re: Indy Hemi Combo
« Reply #5 on: July 07, 2006 - 01:06:45 PM »
Well how did go with that engine, it sounded like real beast... :drool:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Oldschool
Re: Indy Hemi Combo
« Reply #6 on: August 04, 2006 - 10:46:01 AM »
I think this is it...
http://www.cuda-challenger.com/cc/index.php?topic=23697.0
Offline ESGEE
    • SG´s site
Re: Indy Hemi Combo
« Reply #7 on: August 16, 2006 - 06:22:52 PM »
Thanks Oldschool :cheers:
70 Charger 500
nivvy
Re: Indy Hemi Combo
« Reply #8 on: December 17, 2007 - 08:04:59 PM »
I run the BeCool setup and it works great on my StRoKer  :working:
Offline Liu Kang
Re: Indy Hemi Combo
« Reply #9 on: February 28, 2008 - 10:25:12 PM »
hmmm... been wondering, is it cheaper to build your own as compared to buying a crate motor?  can I ask how much it cost to build that?  I thought it might be better with more hps if I pick what parts I want and just have it put togeather... please let me know what you think, thanks
Re: Indy Hemi Combo
« Reply #10 on: July 30, 2010 - 10:48:40 AM »
the Crate is always a compromise , you tend to get the parts they want & may have to replace a few to get what you want + the crate has ben problematic & need to be torn down & checked so I would definatly build one over buying a crate
Offline wiging19
Re: Indy Hemi Combo
« Reply #11 on: August 02, 2010 - 01:21:33 AM »
I can say amen to that statement with a crate 360 380hp engine purchased in 1998.
