I just finished the installation of the Edelbrock Magnum heads and intake on my 360 "LA" (now 408) engine. There was minimal problems adapting it to oil through the pushrods. However, I just noticed that the Magnum intake manifold port for the bypass hose comes straight out instead of at 45 degrees so the moulded factory bypass hose won't fit. Anybody got a pic of a Magnum bypass hose? I think the water pump outlet is in a different location on the Magnums. Any ideas? A moulded hose is required because things are tight.
