Run an MSD ignition and lose the ballast resistor. Not used with their HEI. Then use a spade terminal jumper (radio shack) between ballast resistor terms, seal weathertight, and tuck away hidden in engine harness wire routing. Now to hide the MSD box. Can go inside (behind glove box) or under battery, or ??
