Author Topic: What would you suggest?  (Read 1008 times)
Offline 71chmark
« on: January 17, 2006 - 08:15:37 AM »
I have a 440 with the 440 torquer intake, smog heads and an old 780 dual feed Holley.   Cam is the purple cam (I believe its .284 - .484) and 3.23 rear end.  With about a thousand dollars to work with, what would you suggest would be the best improvement I could make?
I may be schizophrenic,
Offline 1973challenger360
Re: What would you suggest?
« Reply #1 on: January 17, 2006 - 11:03:09 AM »
used roots blower.
what are you trying to do, what has it done.
faster acceleration/higher speed      put in some 4.56 or 2.76 gears           and gas in the tank.
Offline Follicly Challenged
« Reply #2 on: January 17, 2006 - 12:00:40 PM »
Headwork ? Whats you're C.R. ?  Bowlport, and mill the heads .050", add adjustable Valvetrain when doing this.
Just my thoughts, if it's a low CR deal.
Bob out
kudakidd
« Reply #3 on: January 17, 2006 - 12:27:51 PM »
Headwork and gearing (at least 3.55's)
Oldschool
« Reply #4 on: January 17, 2006 - 02:40:18 PM »
 :iagree:  Won't go wrong doing this. And you can do it for $1000.00.  I would go with a 3:91 ratio.   :cooldancing:  .........Oldschool
Offline 71chmark
« Reply #5 on: January 17, 2006 - 02:52:59 PM »
How can I get headwork (what kind) and rear end for a thousand?
« Reply #6 on: January 17, 2006 - 11:57:29 PM »
do you have stock pistons & what year 440 , it may be best to rebuild & port a set of the closed chamber heads to bump the compression
kudakidd
« Reply #7 on: January 18, 2006 - 06:50:03 AM »
Headwork (valve job, bowl work and milld porting should run about $700) check with these guys.
http://www.cylinderheadservices.com/pricing.html
A new ring and pinion set should be about $150 + $150 for installion costs
