Author Topic: Build Sheet????  (Read 953 times)
Offline ambitions2
  • ..we gunna make it to the finish line...
    • 72 Challenger EV-2 Project
Build Sheet????
« on: January 18, 2006 - 01:36:00 PM »
Well I found the build sheet underneath the back seat :drunk:.  It is in great condition, however how should I preserve it, should I laminate it?  Any other suggestions?  If you had a build sheet how'd you do it?  Thanks.
Project: 1972 Challenger - 340 AT 8 3/4 3.23 gears
http://community.webshots.com/user/jtitan2220
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Build Sheet????
« Reply #1 on: January 18, 2006 - 01:52:43 PM »
I just put mine in a clear plastic sleeve that has a flap over the top so nothing can get in/out, then put in a 3 ring binder with hard covers, in a dry place, low humidity.
I'm not sure what happens to lamination after a few years.  I would be afraid it would yellow/crack, depending on the quality.
Also take pics of it and store it on CD.  If they are high resolution you'll be able to zoom in and see the type/codes with out disturbing the original build sheet.
Offline Carlwalski
Re: Build Sheet????
« Reply #2 on: January 18, 2006 - 02:01:08 PM »
Get 2 or 3 color photo copies made. Laminate the original, store one in your "car folder stuff".
Keep one in the car and one somewhere else.
As long as they are in 3 different places and you have the original safely tucked away, you'll be sweet.
Oh yeah, great score mate!! Wish mine was in the car.  :walkaway:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Build Sheet????
« Reply #3 on: January 18, 2006 - 02:36:16 PM »
Great find!  I'm leary about the laminating thing. I put the part of ours that the mice didn't get to in a sheet protector and have it stored away.
Alaskan_TA
Re: Build Sheet????
« Reply #4 on: January 18, 2006 - 07:45:50 PM »
Laminating original documents it bad. The best way is to insert it in an acid free plastic sleave and store it in a safe place. I also reccomend making at least 4 high quality color copies, place three if the same type of sleeves and place them in the seat springs of the car. Use the 4th one for reference when needed.
T/Ake care,
Barry
