Author Topic: Dana rear end  (Read 1870 times)
Offline greengochallenger
Dana rear end
« on: January 20, 2006 - 08:51:32 PM »
While looking around an old junkyard today, I found a Dana 60 in a Dodge van. It is a 3/4 ton rear end, i guess, cause it has the 8 lug wheels. Is the housing the same? Could you get different housing ends & axles to place it in a challenger?
Offline Blown70
Re: Dana rear end
« Reply #1 on: January 21, 2006 - 08:55:26 AM »
Sure cut it down I think dont you then buy some axels and put the pads where you want.
The only difference in trunk dana's is the lack of a pinion snubber provision.  Of course the axles too but you can change them I believe.
Tom
Re: Dana rear end
« Reply #2 on: January 21, 2006 - 12:55:59 PM »
We used to nodify a lot of Danas like this , the housing ends are available for use with green brgs , new 35 spline axles are required as well
no the bad news , the Van diff is offset to far too the right to work in most stock width B & E body cars , the ford & Dodge  3/4 ton diffs will work & are easy to get
« Last Edit: January 21, 2006 - 01:17:13 PM by Chryco Psycho »
Offline Blown70
Re: Dana rear end
« Reply #3 on: January 21, 2006 - 01:05:00 PM »
no the bad news , the Van diff is offset to far to the right to work in most stock width B & E body cars , the ford & Dodge  3/4 ton diffs will work & are easy to get
AHHH I did not know they were offset in a van... Good to know.
Tom :thumbsup:
Offline GreenFish
Re: Dana rear end
« Reply #4 on: February 09, 2006 - 01:04:57 PM »
My friends and I have found that it is worth it to just buy a new rear end if you are swaping out. Unless you find the exact size you need, by the time you pay someone to modify the tubes cut new axles and all that you could have bought a brand new set up from Moser or someplace like that.
cudahob
Re: Dana rear end
« Reply #5 on: February 09, 2006 - 01:11:35 PM »
Well I found a 3/4 ton truck Dana 60 suregrip. I could have got it for $60 bucks, but I didn't need it.
Re: Dana rear end
« Reply #6 on: February 09, 2006 - 05:07:07 PM »
50/50 , with the work involved to modify a Dana it generally runs $1000 approx + time to order parts & run around & a new assy is $1500 or more & shipping to here is expensive so for me it is easier to modfy them
« Last Edit: April 24, 2006 - 01:17:41 PM by Chryco Psycho »
Offline GreenFish
Re: Dana rear end
« Reply #7 on: April 24, 2006 - 12:31:09 PM »
I called DTS and Strange.. both wanted $2500 or so for a full brand new set up dana WITH disc brakes.. cut off about 6-700 bucks without the brakes. This also included a pinion snubber and all. They start at 1800.
